Configure ICL Port Mirroring in a Multi-Tenant Architecture
  1. Run the following commands to configure access control list applications on Ethernet or port channel and VLAN or virtual Ethernet:
    efa tenant epg create --name <epg-name> --tenant <tenant-name>
            --type port-profile
            --po <mirror-source-po-list>
            --pp-ipv6-acl-in <acl-name>
            --pp-ip-acl-in <acl-name> --pp-ip-acl-out <acl-name>
  2. Run the following commands to configure a mirror session:
    efa tenant service mirror session create –name <session-name> --tenant <tenant-name>
        --source {<device-ip>,<eth | po | vlan>,<if-name>}
        --type {<source-device-ip>,<eth | po | vlan>,<source-if-name>:<port-based | flow-based>}
        --destination-type {<source-device-ip>,< eth | po | vlan>,<source-if-name>:<span>}
        --destination {<source-device-ip>,<eth | po | vlan>,<source-if-name> :
    			<destination-device-ip>,<eth | po | vlan>,<destination-if-name}
        --direction {<source-device-ip>,< eth | po | vlan>,<source-if-name> : <tx | rx | both>}
    (efa:root)root@node-2:~# efa tenant show
    | Name   |  Type  | VLAN  | L2VNI | L3VNI | VRF   | Enable |            Ports            |   Mirroring Ports  |
    |        |        | Range | Range | Range | Count | BD     |                             |                    |
    | shared | Shared |       |       |       |   0   | false  | 10.20.246.15[0/46-47]       | 10.20.246.15[0/31] |
    | Tenant |        |       |       |       |       |        | 10.20.246.16[0/46-47]       | 10.20.246.16[0/31] |
    |        |        |       |       |       |       |        | 10.20.246.21[0/9-10,0/46-48]| 10.20.246.21[0/31] |
    |        |        |       |       |       |       |        | 10.20.246.22[0/9-10,0/46-48]| 10.20.246.22[0/31] |
    |        |        |       |       |       |       |        |                             | 10.20.246.25[0/31] |
    |        |        |       |       |       |       |        |                             | 10.20.246.26[0/31] |
    (efa:root)root@node 2:~# efa tenant po show
    |   Name  | Tenant | ID | Speed  | MTU | Negotiation | Min Link |  Lacp   |          Ports              |    State   |  Dev State  |  App State  |
    |         |        |    |        |     |             |   Count  | Timeout |                             |            |             |             |
    | ten1po1 | ten1   | 64 | 10Gbps |     |    active   |    1     |   long  | 10.20.246.15[0/46-47]       | po-created | provisioned | cfg-in-sync |
    |         |        |    |        |     |             |          |         | 10.20.246.16[0/46-47]       |            |             |             |
    | ten2po1 | ten2   | 64 | 10Gbps |     |    active   |    1     |   long  | 10.20.246.21[0/9-10,0/46-48]| po-created | provisioned | cfg-in-sync |
    |         |        |    |        |     |             |          |         | 10.20.246.22[0/9-10,0/46-48]|            |             |             |
    efa tenant epg create –name ten1epg1 –tenant ten1 --type port-profile
             --po ten1po1
             --pp-ipv6-acl-in ext-ipv6-permit-any-mirror-acl
    efa tenant service mirror session create –name mirrorsession1 --tenant ten1
                  --source 10.20.246.15,po,ten1po1
                  --type 10.20.246.15,po,ten1po1:port-based
                  --destination 10.20.246.15,po,ten1po1:10.20.246.15,eth,0/31
                  --destination-type 10.20.246.15,po,ten1po1:span
                  --direction 10.20.246.15,po,ten1po1:tx
    efa tenant service mirror session create –name mirrorsession2 --tenant ten1
                  --type 10.20.246.15,po,ten1po1:flow-based
                  --direction 10.20.246.15,po,ten1po1:rx
    efa tenant epg create –name ten1epg2 –tenant ten1 --type port-profile
                  --po ten1po2
    efa tenant service mirror session create –name mirrorsession3 --tenant ten1
                   --source 10.20.246.21,po,ten1po2
                   --type 10.20.246.21,po,ten1po2:port-based
                   --destination 10.20.246.21,po,ten1po2:10.20.246.21,eth,0/31
                   --destination-type 10.20.246.21,po,ten1po2:span
                   --direction 10.20.246.21,po,ten1po2:tx
    efa tenant service mirror session create –name mirrorsession4 --tenant ten1
                  --type 10.20.246.21,po,ten1po2:flow-based
                  --direction 10.20.246.21,po,ten1po2:rx
  3. Verify the switch configuration on the SLX device.
    10.20.246.15
    SLX# show running-config ipv6 access-list
    ipv6 access-list extended ext-ipv6-permit-any-mirror-acl
     seq 10 permit ipv6 any any mirror
    SLX#
    SLX# show running-config int po 64
    interface Port-channel 64
     mtu 9216
     description MCTPeerInterface
     ip address 10.20.20.3/31
     ipv6 access-group ext-ipv6-permit-any-mirror-acl in
     no shutdown
    SLX#
    10.20.246.16
    SLX#
     mtu 9216
     ip address 10.20.20.2/31
     no shutdown
    SLX#
    10.20.246.21
    SLX#
     mtu 9216
     no shutdown
    SLX#
    10.20.246.22
    SLX#
     mtu 9216
     no shutdown
    SLX#
    10.20.246.15
    SLX# show running-config monitor session
    monitor session 1
     source port-channel 64 destination ethernet 0/31 direction tx
    monitor session 2
     source port-channel 64 destination ethernet 0/31 direction rx flow-based
    SLX# show monitor session 1
    Session                : 1
    Type                   : SPAN
    Description            : [None]
    State                  : Enabled
    Source Interface       : Po 64 (Up)
    Destination Interface  : Eth 0/31 (Down)
    Direction              : Tx
    Type                   : port-based
    SLX# show monitor session 2
    Session                : 2
    Type                   : SPAN
    State                  : Enabled
    Direction              : Rx
    Type                   : flow-based
    10.20.246.21
    monitor session 1
    monitor session 2
    Session                : 1
    Type                   : SPAN
    State                  : Enabled
    Direction              : Tx
    Type                   : port-based
    Session                : 2
    Type                   : SPAN
    State                  : Enabled
    Direction              : Rx
    Type                   : flow-based
