Configure VLAN-Based Mirroring in a Multi-Tenant Architecture
VLAN based mirroring applies only to VLAN-based tenants and not to BD (bridge domain)-based tenants.
  1. Run the following commands to configure access control list applications on Ethernet or port channel and VLAN or virtual Ethernet:
    efa tenant epg create --name <epg-name> --tenant <tenant-name>
                --switchport --switchport-mode trunk –ctag-range <ctag-range>
                --port <mirror-source-port-list> --po <mirror-source-po-list>
                --pp-mac-acl-in <acl-name> --pp-mac-acl-out <acl-name>
                --pp-ip-acl-in <acl-name> --pp-ip-acl-out <acl-name>
                --np-mac-acl-in <ctag:acl-name> --np-mac-acl-out <ctag:acl-name>
                --np-ip-acl-in <ctag:acl-name> --np-ip-acl-out <ctag:acl-name>
  2. Run the following commands to configure a mirror session:
    efa tenant service mirror session create –name <session-name> --tenant <tenant-name>
                --source {<device-ip>,<eth | po | vlan>,<if-name>}
                --type {<source-device-ip>,<eth | po | vlan>,<source-if-name>:<port-based | flow-based>}
                --destination {<source-device-ip>,<eth | po | vlan>,<source-if-name> :
                            <destination-device-ip>,<eth | po | vlan>,<destination-if-name}
                --destination-type {<source-device-ip>,< eth | po | vlan>,<source-if-name>:<span>}
                --direction {<source-device-ip>,< eth | po | vlan>,<source-if-name> : <tx | rx | both>}
    (efa:root)root@node-2:~# efa tenant show
    | Name   |  Type   | VLAN  | L2VNI | L3VNI | VRF   | Enable |         Ports        |   Mirroring Ports  |
    |        |         | Range | Range | Range | Count | BD     |                      |                    |
    | shared | Shared  |       |       |       |   0   | false  |                      | 10.20.246.16[0/31] |
    | Tenant |         |       |       |       |       |        |                      | 10.20.246.21[0/31] |
    |        |         |       |       |       |       |        |                      | 10.20.246.22[0/31] |
    |        |         |       |       |       |       |        |                      | 10.20.246.25[0/31] |
    |        |         |       |       |       |       |        |                      | 10.20.246.26[0/31] |
    |  ten1  | private | 11-20 |       |       |   10  | false  | 10.20.246.15[0/1-10] |                    |
    |        |         |       |       |       |       |        | 10.20.246.16[0/1-10] |                    |
    |        |         |       |       |       |       |        | 10.20.246.21[0/1-10] |                    |
    |        |         |       |       |       |       |        | 10.20.246.22[0/1-10] |                    |
    |  ten2  | private | 21-30 |       |       |   10  | false  | 10.20.246.15[0/11-20]|                    |
    |        |         |       |       |       |       |        | 10.20.246.16[0/11-20]|                    |
    |        |         |       |       |       |       |        | 10.20.246.21[0/11-20]|                    |
    |        |         |       |       |       |       |        | 10.20.246.22[0/11-20]|                    |
    (efa:root)root@node 2:~# efa tenant po show
    |   Name  | Tenant | ID |  Speed  | MTU | Negotiation | Min Link |  Lacp   |        Ports      |    State   |  Dev State  |  App State  |
    |         |        |    |         |     |             |   Count  | Timeout |                   |            |             |             |
    | ten1po1 | ten1   |  2 |  10Gbps |     |    active   |    1     |   long  | 10.20.246.15[0/1] | po-created | provisioned | cfg-in-sync |
    |         |        |    |         |     |             |          |         | 10.20.246.16[0/1] |            |             |             |
    | ten2po1 | ten2   |  3 |  10Gbps |     |    active   |    1     |   long  | 10.20.246.15[0/11]| po-created | provisioned | cfg-in-sync |
    |         |        |    |         |     |             |          |         | 10.20.246.16[0/11]|            |             |             |
    | ten1po2 | ten1   |  2 |  10Gbps |     |    active   |    1     |   long  | 10.20.246.21[0/1] | po-created | provisioned | cfg-in-sync |
    |         |        |    |         |     |             |          |         | 10.20.246.22[0/1] |            |             |             |
    | ten2po2 | ten2   |  3 |  10Gbps |     |    active   |    1     |   long  | 10.20.246.21[0/11]| po-created | provisioned | cfg-in-sync |
    |         |        |    |         |     |             |          |         | 10.20.246.22[0/11]|            |             |             |
    efa tenant epg create –name ten1epg1 –tenant ten1
                --switchport-mode trunk --po ten1po1,ten1po2  --ctag-range 11
                --np-mac-acl-in 11:ext-mac-permit-any-mirror-acl
                --np-mac-acl-out 11:ext-mac-permit-any-mirror-acl
    efa tenant service mirror session create –name ten1mirrorsession1 --tenant ten1
                --source vlan,11
                --type vlan,11:flow-based
                --destination-type vlan,11:span
                --destination vlan,11:10.20.246.15,eth,0/31
                --direction vlan,11:both
    efa tenant epg create –name ten2epg1 –tenant ten2
                --switchport-mode trunk --po ten2po1,ten2po2 --ctag-range 21
                --np-mac-acl-in 21:ext-mac-permit-any-mirror-acl
                --np-mac-acl-out 21:ext-mac-permit-any-mirror-acl
    efa tenant service mirror session create –name ten2mirrorsession1 --tenant ten2
                --source vlan,21
                --type vlan,21:flow-based
                --destination-type vlan,21:span
                --destination vlan,21:10.20.246.16,eth,0/31
                --direction vlan,21:both
  3. Verify the switch configuration on the SLX device.
    10.20.246.15
    SLX# show running-config mac access-list
    mac access-list extended ext-mac-permit-any-mirror-acl
     seq 10 permit any any mirror
    SLX#
    SLX# show running-config vlan 11,21
    vlan 11
     description Tenant L2 Extended VLAN
     mac access-group ext-mac-permit-any-mirror-acl in
     mac access-group ext-mac-permit-any-mirror-acl out
    vlan 21
    SLX#
    10.20.246.16
    SLX#
    vlan 11
    vlan 21
    SLX#
    10.20.246.21
    SLX#
    vlan 11
    vlan 21
    SLX#
    10.20.246.22
    SLX#
    vlan 11
    vlan 21
    SLX#
    10.20.246.15-16
    SLX# show running-config monitor session
    monitor session 1
     source vlan 11 destination ethernet 0/31 direction both flow-based
    monitor session 2
     source vlan 21 destination ethernet 0/31 direction both flow-based
    !SLX#
    SLX# show monitor session 1
    Session                : 1
    Type                   : SPAN
    Description            : [None]
    State                  : Enabled
    Source Interface       : Vlan 11
    Destination Interface  : Eth 0/31 (Down)
    Direction              : Both
    Type                   : flow-based
    SLX# show monitor session 2
    Session                : 2
    Type                   : SPAN
    State                  : Enabled
    Source Interface       : Vlan 21
    Direction              : Both
    Type                   : flow-based
    SLX#
    10.20.246.21-22
    monitor session 1
    monitor session 2
    !SLX
    #SLX# show monitor session 1
    Session                : 1
    Type                   : SPAN
    State                  : Enabled
    Direction              : Both
    Type                   : flow-based
    Session                : 2
    Type                   : SPAN
    State                  : Enabled
    Direction              : Both
    Type                   : flow-based
    SLX#
