Drift and Reconcile (DRC) and Idempotency for route map configuration
The following table captures the various attributes of route map for which DRC and idempotency is supported.
Table 1. IP prefix list attributes supporting DRC and idempotency
Field Identify Drift Reconcile config Idempotency Comments
Route map deleted Yes Yes No Recreate the route map along with the match criteria during reconcile
Route map rule action updated Yes Yes No Reconcile the route map action (permit/deny) for that rule
Update IPv4 prefix list name in match criteria Yes Yes No Reconcile the IPv4 prefix list name
IPv4 prefix list match criteria deleted Yes Yes NA Reconcile the match criteria for IPv4 prefix list
A different match criteria NOT supported by EFA is added through OOB No No NA
A set criteria NOT supported by EFA is added through OOB No No NA
Route map is created through OOB and this is not present/created by EFA No No NA
