Shared VRF and Router Usecase with Examples
Topology
efa fabric create --name fabric1 --type non-clos
efa fabric setting update --name fabric1
           --vni-auto-map No --backup-routing-enable Yes
efa fabric device add-bulk --name fabric1
           --rack rack1 --ip 10.20.246.25-26 --rack rack2 --ip 10.20.246.17-18
           --border-leaf-rack rack3 --border-leaf-ip 10.20.246.15-16
           --username admin --password password
efa fabric configure --name fabric1
efa fabric show
Fabric Name: default, Fabric Description: Default Fabric, Fabric Stage: 3, Fabric Type: clos, Fabric Status: created
| IP ADDRESS | POD | HOST NAME | ASN | ROLE | DEVICE STATE | APP STATE | CONFIG GEN REASON | PENDING CONFIGS | VTLB ID | LB ID |
Fabric Name: fs, Fabric Description: , Fabric Stage: 3, Fabric Type: clos, Fabric Status: settings-updated
Updated Fabric Settings: BGP-LL
| 10.20.246.1 | | SLX-1 | 64512 | Spine | provisioned | cfg in-sync | NA | NA | NA | 1 |
| 10.20.246.7 | | SLX | 65000 | Leaf | provisioning failed | cfg ready | IA,IU,MD,DA | SYSP-C,MCT-C,MCT-PA,BGP-C,INTIP-C,EVPN-C,O-C | 2 | 1 |
| 10.20.246.8 | | slx-8 | 65000 | Leaf | provisioned | cfg in-sync | NA | NA | 2 | 1 |
FABRIC SETTING:
BGPLL - BGP Dynamic Peer Listen Limit, BGP-MD5 - BGP MD5 Password , BFD-RX - Bfd Rx Timer, BFD-TX - Bfd Tx Timer, BFD-MULTIPLIER - Bfd multiplier,
BFD-ENABLE - Enable Bfd, BGP-MULTIHOP - BGP ebgp multihop, P2PLR - Point-to-Point Link Range, MCTLR - MCT Link Range, LOIP - Loopback IP Range
CONFIG GEN REASON:
LA/LD - Link Add/Delete, IA/ID/IU - Interface Add/Delete/Update, PLC/PLD/PLU - IPPrefixList Create/Delete/Update
MD/MU - MCT Delete/Update, OD/OU - Overlay Gateway Delete/Update, EU/ED - Evpn Delete/Update, PC/PD/PU - RouterPim Create/Delete/Update
DD - Dependent Device Update, DA/DR - Device Add/ReAdd, ASN - Asn Update, SYS - System Properties Update
MD5 - BGP MD5 Password, BGPU - Router BGP Update, BGPLL - BGP Listen Limit, POU - Port Channel Update, NA - Not Applicable
PENDING CONFIGS:
MCT - MCT Cluster, O - Overlay Gateway, SYSP - System Properties, INTIP - Interface IP, BGP - Router BGP
C/D/U - Create/Delete/Update, PA/PD - Port Add/Port Delete
Shared VRF Configuration Overview
Shared Tenant and Private Tenant Configuration
efa tenant create --name sharedTenant --type shared --port 10.20.246.15[0/31],10.20.246.16[0/31]
    --vrf-count 10 --l3-vni-range 31001-31020
    --vlan-range 31-40 --l2-vni-range 30011-30020
efa tenant create --name tenant1 --port 10.20.246.17[0/11-20],10.20.246.18[0/11-20],10.20.246.25[0/11-20],10.20.246.26[0/11-20]
    --vlan-range 11-20 --l2-vni-range 10011-10020 --vrf-count 10 --l3-vni-range 11001-11020
efa tenant create --name tenant2 --port 10.20.246.17[0/21-30],10.20.246.18[0/21-30],10.20.246.25[0/21-30],10.20.246.26[0/21-30]
    --vlan-range 21-30 --l2-vni-range 20011-20020 --vrf-count 10 --l3-vni-range 21001-21020
efa tenant show
|     Name     |  Type   | VLAN Range | L2VNI Range | L3VNI Range | VRF Count | Enable BD |         Ports         |
| sharedTenant | shared  |   31-40    | 30011-30020 | 31001-31020 |    10     |   false   |  10.20.246.15[0/31]   |
|              |         |            |             |             |           |           |  10.20.246.16[0/31]   |
|   tenant1    | private |   11-20    | 10011-10020 | 11001-11020 |    10     |   false   | 10.20.246.18[0/11-20] |
|              |         |            |             |             |           |           | 10.20.246.17[0/11-20] |
|              |         |            |             |             |           |           | 10.20.246.25[0/11-20] |
|              |         |            |             |             |           |           | 10.20.246.26[0/11-20] |
|   tenant2    | private |   21-30    | 20011-20020 | 21001-21020 |    10     |   false   | 10.20.246.26[0/21-30] |
|              |         |            |             |             |           |           | 10.20.246.18[0/21-30] |
|              |         |            |             |             |           |           | 10.20.246.17[0/21-30] |
|              |         |            |             |             |           |           | 10.20.246.25[0/21-30] |
Shared PO and Private PO Configuration
efa tenant po create --name sharedPO --tenant sharedTenant
                   --port 10.20.246.15[0/31],10.20.246.16[0/31] --speed 10Gbps --negotiation active
efa tenant po create --name ten1po1 --tenant tenant1
                   --port 10.20.246.17[0/11],10.20.246.18[0/11] --speed 10Gbps --negotiation active
efa tenant po create --name ten1po2 --tenant tenant1
                   --port 10.20.246.25[0/11],10.20.246.26[0/11] --speed 10Gbps --negotiation active
efa tenant po create --name ten2po1 --tenant tenant2
                   --port 10.20.246.17[0/21],10.20.246.18[0/21] --speed 10Gbps --negotiation active
efa tenant po create --name ten2po2 --tenant tenant2
                   --port 10.20.246.25[0/21],10.20.246.26[0/21] --speed 10Gbps --negotiation active
efa tenant po show
|   Name   |    Tenant    | ID | Speed  | Negotiation | Min Link |  Lacp   |       Ports        |   State    |  Dev State  |  App State  |
|          |              |    |        |             |  Count   | Timeout |                    |            |             |             |
| sharedPO | sharedTenant | 1  | 10Gbps |   active    |    1     |  long   | 10.20.246.16[0/31] | po-created | provisioned | cfg-in-sync |
|          |              |    |        |             |          |         | 10.20.246.15[0/31] |            |             |             |
| ten1po1  |   tenant1    | 1  | 10Gbps |   active    |    1     |  long   | 10.20.246.18[0/11] | po-created | provisioned | cfg-in-sync |
|          |              |    |        |             |          |         | 10.20.246.17[0/11] |            |             |             |
| ten1po2  |   tenant1    | 1  | 10Gbps |   active    |    1     |  long   | 10.20.246.25[0/11] | po-created | provisioned | cfg-in-sync |
|          |              |    |        |             |          |         | 10.20.246.26[0/11] |            |             |             |
| ten2po1  |   tenant2    | 2  | 10Gbps |   active    |    1     |  long   | 10.20.246.18[0/21] | po-created | provisioned | cfg-in-sync |
|          |              |    |        |             |          |         | 10.20.246.17[0/21] |            |             |             |
| ten2po2  |   tenant2    | 2  | 10Gbps |   active    |    1     |  long   | 10.20.246.25[0/21] | po-created | provisioned | cfg-in-sync |
|          |              |    |        |             |          |         | 10.20.246.26[0/21] |            |             |             |
Shared VRF and Private VRF
efa tenant vrf create --name sharedVrf --tenant sharedTenant
efa tenant vrf create --name ten1vrf1 --tenant tenant1
efa tenant vrf create --name ten2vrf1 --tenant tenant2
efa tenant vrf show
|   Name    |    Tenant    | Routing Type | Centralized Routers | Redistribute | Max Path | Local Asn | Enable GR |   State    |    Dev State    | App State |
| sharedVrf | sharedTenant | distributed  |                     |  connected   |    8     |           |   false   | vrf-create | not-provisioned | cfg-ready |
| ten1vrf1  |   tenant1    | distributed  |                     |  connected   |    8     |           |   false   | vrf-create | not-provisioned | cfg-ready |
| ten2vrf1  |   tenant2    | distributed  |                     |  connected   |    8     |           |   false   | vrf-create | not-provisioned | cfg-ready |
Shared VRF: Inter POD Routing
efa tenant epg show
|   Name   | Tenant  |   Type    | Ports |   PO    | SwitchPort | Native Vlan | Ctag Range |    Vrf    | L3Vni | State |
|          |         |           |       |         |    Mode    |   Tagging   |            |           |       |       |
| ten1epg1 | tenant1 | extension |       | ten1po2 |   trunk    |    false    |     11     | sharedVrf | 31001 |       |
|          |         |           |       | ten1po1 |            |             |            |           |       |       |
| ten1epg2 | tenant1 | extension |       | ten1po1 |   trunk    |    false    |     13     | ten1vrf1  | 11001 |       |
|          |         |           |       | ten1po2 |            |             |            |           |       |       |
| ten2epg1 | tenant2 | extension |       | ten2po1 |   trunk    |    false    |     21     | sharedVrf | 31001 |       |
|          |         |           |       | ten2po2 |            |             |            |           |       |       |
| ten2epg2 | tenant2 | extension |       | ten2po2 |   trunk    |    false    |     23     | ten2vrf1  | 21001 |       |
|          |         |           |       | ten2po1 |            |             |            |           |       |       |
L3 Handoff Using EPG and BGP Peer Owned by Shared Tenant Using Shared VRF
efa tenant epg show
| sharedTenepg1 | sharedTenant | l3-hand-off |       | sharedPO |   trunk    |    false    |     31     | sharedVrf | 31001 |       |
|   ten1epg2    |   tenant1    |  extension  |       | ten1po2  |   trunk    |    false    |     13     | ten1vrf1  | 11001 |       |
|   ten1epg3    |   tenant1    | l3-hand-off |       | sharedPO |   trunk    |    false    |     20     | ten1vrf1  | 11001 |       |
|   ten1epg4    |   tenant1    | l3-hand-off |       | sharedPO |   trunk    |    false    |     19     | sharedVrf | 31001 |       |
|   ten2epg3    |   tenant2    | l3-hand-off |       | sharedPO |   trunk    |    false    |     30     | ten2vrf1  | 21001 |       |
|   ten2epg1    |   tenant2    |  extension  |       | ten2po2  |   trunk    |    false    |     21     | sharedVrf | 31001 |       |
|   ten2epg2    |   tenant2    |  extension  |       | ten2po1  |   trunk    |    false    |     23     | ten2vrf1  | 21001 |       |
efa tenant service bgp peer show --detail
Tenant           : sharedTenant
State            : bs-state-created
Description      :
Static Peer
        Device IP        : 10.20.246.15
        VRF              : sharedVrf
        AFI              : ipv4
        SAFI             : unicast
        Remote IP        : 10.0.31.3
        Remote ASN       : 50000
        Next Hop Self    : false
        Update Source IP :
        BFD Enabled      : false
        BFD Interval     : 0
        BFD Rx           : 0
        BFD Multiplier   : 0
        MD5 Password     :
        Dev State        : provisioned
        App State        : cfg-in-sync
        Device IP        : 10.20.246.16
        VRF              : sharedVrf
        AFI              : ipv4
        SAFI             : unicast
        Remote ASN       : 50000
        Update Source IP :
        BFD Enabled      : false
        BFD Interval     : 0
        BFD Rx           : 0
        BFD Multiplier   : 0
        MD5 Password     :
Dynamic Peer
        0 Records
