Software BFD Session Support on CEP
BFD Session Formation with SRIOV Server
During initial state of BFD session formation with SRIOV (single-root input or output virtualization) server:
  • For MCT-1:
    • The nexthop reachability for 10.1.1.3 is via ICL.
    • It forms a Software BFD session with 10.1.1.3 is via ICL. It also forms a Software BFD session with 10.1.1.3.
  • For MCT-2:
    • The nexthop reachability for 10.1.1.3 is via CEP port eth 0/1.
    • It forms a Hardware BFD session with 10.1.1.3.
BFD Session Formation with SRIOV Server after Link Failover
During the link failover of BFD session formation with SRIOV (single-root input/output virtualization) server:
  • For MCT-1:
    • The Nexthop reachability for 10.1.1.3 changes from ICL to its CEP eth 0/1.
    • The BFD session changes from Software to Hardware. BFD reachability for 10.1.1.3 changes from ICL to its CEP eth 0/1. The BFD session changes from Software to Hardware BFD.
  • For MCT-2:
    • The Nexthop reachability for 10.1.1.3 changes from CEP eth 0/1 to ICL.
    • The BFD session changes from Hardware to Software BFD.
cep-bfd-session-type Automation on EPG (Endpoint Group) Port Property
EFA automates the cep-bfd-session-type on the CEP interfaces based on the logic, with no additional input from the users.
SLX Hardware Type EFA: Fabric Links (Leaf to Spine) EFA: Extension EPG EFA: L3-Handoff EPG
CEP SRIOV CEP Non-SRIOV CEP
SLX 9250 Hardware Software Software Hardware
SLX 8720 Hardware Software Software Hardware
SLX 9740 and other SLX versions Hardware Hardware Hardware Hardware
(efa:root)root-2:-# efa fabric show
Fabric Name: default, Fabric Description: Default Fabric, Fabric Stage: 3, Fabric Type: clos, Fabric Status: created
| IP ADDRESS | POD | HOST NAME | ASN | ROLE | DEVICE STATE | APP STATE | CONFIG GEN REASON | PENDING CONFIGS | VTLB ID | LB ID |
Fabric Name: fs, Fabric Description: , Fabric Stage: 3, Fabric Type: clos, Fabric Status: settings-updated
Updated Fabric Settings: BGP-LL
| 10.20.246.1 | | SLX-1 | 64512 | Spine | provisioned | cfg in-sync | NA | NA | NA | 1 |
| 10.20.246.7 | | SLX | 65000 | Leaf | provisioning failed | cfg ready | IA,IU,MD,DA | SYSP-C,MCT-C,MCT-PA,BGP-C,INTIP-C,EVPN-C,O-C | 2 | 1 |
| 10.20.246.8 | | slx-8 | 65000 | Leaf | provisioned | cfg in-sync | NA | NA | 2 | 1 |
FABRIC SETTING:
BGPLL - BGP Dynamic Peer Listen Limit, BGP-MD5 - BGP MD5 Password , BFD-RX - Bfd Rx Timer, BFD-TX - Bfd Tx Timer, BFD-MULTIPLIER - Bfd multiplier,
BFD-ENABLE - Enable Bfd, BGP-MULTIHOP - BGP ebgp multihop, P2PLR - Point-to-Point Link Range, MCTLR - MCT Link Range, LOIP - Loopback IP Range
CONFIG GEN REASON:
LA/LD - Link Add/Delete, IA/ID/IU - Interface Add/Delete/Update, PLC/PLD/PLU - IPPrefixList Create/Delete/Update
MD/MU - MCT Delete/Update, OD/OU - Overlay Gateway Delete/Update, EU/ED - Evpn Delete/Update, PC/PD/PU - RouterPim Create/Delete/Update
DD - Dependent Device Update, DA/DR - Device Add/ReAdd, ASN - Asn Update, SYS - System Properties Update
MD5 - BGP MD5 Password, BGPU - Router BGP Update, BGPLL - BGP Listen Limit, POU - Port Channel Update, NA - Not Applicable
PENDING CONFIGS:
MCT - MCT Cluster, O - Overlay Gateway, SYSP - System Properties, INTIP - Interface IP, BGP - Router BGP
C/D/U - Create/Delete/Update, PA/PD - Port Add/Port Delete
(efa:root)root-2:-# efa tenant show
| Name |   Type  | VLAN Range | L2VNI Range | L3VNI Range | VRF Count |  Enable BD |         Ports        |
| ten1 | Private |    11-20   |             |             |     10    |    false   | 10.20.246.6[0/1-10]| |
|      |         |            |             |             |           |            | 10.20.246.5[0/1-10]| |
efa tenant vrf create --name ten1vrf1 --tenant ten1
EPG Create
Run the following command to create a cep-bfd-session-type automation on EPG port property:
efa tenant epg create --name ten1epg1 --tenant ten1
        --port 10.20.246.5[0/1],10.20.246.6[0/1]
        --switchport-mode trunk
        --vrf ten1vrf1 --ctag-range 11
        --anycast-ip 11:20.0.11.1/24
        --local-ip 11,10.20.246.5:10.1.1.1/24 --local-ip 11,10.20.246.6:10.1.1.2/24
(efa:root)root@node-2:-# efa tenant epg show  --detail
Tenant        : ten1
Type          : extension
State         :
Description   :
Ports         : 10.20.246.5[0/1]
              : 10.20.246.6[0/1]
POs           :
Port Property : SwithchPort Mode    : trunk
              : Native Vlan Tagging : false
              : BFD Session Type    : Auto
NW Policy     : Ctag Range         : 11
              : VRF                : ten1vrf1
              : L3Vni              : 8192
| Ctag |            Ctag         | L2Vni | BD Name | Anycast IPv4 | Anycast IPv6 |         Local IP         | IPv6 ND |     IPv6 ND    |    IPv6 ND   |  Dev State  |  App State  |
|      |        Description      |       |         |              |              |  [Device-IP->Local-IP]   |   Mtu   | Managed Config | Other Config |             |             |
|  11  | Tenant L3 Extended VLAN |  11   |         | 20/0.11.1/24 |              | 10.20.246.5->10.1.1.1/24 |         |      false     |     false    | provisioned | cfg-in-sync |
|      |                         |       |         |              |              | 10.20.246.6->10.1.1.1/24 |         |                |              |             |             |
Network Property [Flags : * - Native Vlan]
| CTAG | IPv6 ND Prefix | No Advertise | Valid Lifetime | Preferred Lifetime | Config Type |
IPv6 ND Prefix Flags
For 'unstable' entities, run 'efa tenant po/vrf show' for details
VRF Update
Run the following command to update a tenant VRF on the static route BFD:
efa tenant vrf update --name ten1vrf1 --tenant ten1
        --operation static-route-bfd-add
        --ipv4-static-route-bfd 10.20.246.5,10.1.1.3,10.1.1.1
        --ipv4-static-route-bfd 10.20.246.6,10.1.1.3,10.1.1.2
(efa:root)root@node-2:-# efa tenant vrf show  --detail
Tenant                  : ten1
Type                    : extension
Routing Type            : distributed
Centralized Routers     :
Redistribute            : connected
Max Path                : 8
Local ASN               :
L3VNI                   : 8192
EVPN IRB BD             : 4096
EVPN IRB VE             : 8192
BR VNI                  : 4096
BR BD                   :
BR VE                   :
RH Max Path             :
Enable RH ECMP          : false
Enable Graceful Restart : false
Route Target            : import 101:101
                        : export 101:101
Static Route            :
Static Rout BFD         : Switch-IP->[DestIP,SourceIP][Interval,Min-Rx,Multiplier], ...
                        : 10.20.246.6->10.1.1.3,10.1.1.2
                        : 10.20.246.5->10.1.1.3,10.1.1.1
State                   : vrf-device-created
Dev State               : provisioned
App State               : cfg-in-sync
Switch Config
Rack1-Device1(config)# do show running-config vlan 11
vlan 11
 router interface Ve 11
 suppress-arp
 description Tenant L3 Extended VLAN
Rack1-Device1(config)# do show running config interface Ve 11
interface Ve 11
 vrf forwarding ten1vrf1
 ip anycast address 20.0.11.1/24
 ip address 10.1.1.1/24
 no shutdown
Rack1-Device1(config)# do show running config interface Ethernet 0/1
 cluster-track
 bfd software session
 switchport
 switchport mode trunk
 switchport trunk allowed vlan add 11
 no switchport trunk tag native-vlan
 no shutdown
Rack1-Device1(config)# do show running config vrf ten1vrf1 address family
ipv4 unicast
vrf ten1vrf1
 address family ipv4 unicast
  route target export 101:101 evpn
  route target import 101:101 evpn
  ip route static bfd 10.1.1.3 10.1.1.1
Rack1-Device2(config)# do show running config vlan 11
vlan 11
 suppress arp
Rack1Device2(config)# do show running config in Ve 11
interface Ve 11
 ip address 10.1.1.2/24
 no shutdown
Rack1Device2(config)# do show running config int eth 0/1
 cluster track
 switchport
 no shutdown
Rack1-Device2(config)# do show running config vrf ten1vrf1 address family
ipv4 unicast
vrf ten1vrf1
  ip route static bfd 10.1.1.3 10.1.1.2
cep-bfd-session-type on EPG Port Property
EPG Create EPG Update
efa tenant epg create --name < epg-name> --tenant <tenant-name>
 --port <port-list> po <po-list>
 --switchport-mode <access | trunk> --cep-bfd-session-type {auto | software | hardware}
efa tenant epg update --name < epg-name> tenant <tenant-name>
 --operation port group add
 --port <port-list> --po <po-list>
 switchport-mode < access|trunk > --cep-bfd-session-type {auto | software | hardware}
CEP SRIOV and Non SRIOV Upgrade Handling
  • EFA cannot distinguish between the SRIOV and Non-SRIOV connections. Hence both the CEP SRIOV and CEP Non-SRIOV phy or port channel are treated in same manner.
  • To use the “hardware” bfd sessions for the CEP Non-SRIOV connections, create an EPG containing all the Non-SRIOV CEP with cep bfd session type=hardware.
During the upgrade from EFA 2.4.0 to 2.4.1 and onwards, all the CEP ports (on SLX 9250 and SLX 8720 platforms) used in the “extension” EPG must have cep bfd session type as software, and you must perform an explicit DRC to reconcile the EFA configuration to synchronize with the SLX.
Co-existence of centralize and distributed routing on a CEP
