Configure Port-Based Mirroring in a Multi-Tenant Architecture
  1. Run the following commands to configure access control list applications on Ethernet or port channel and VLAN or virtual Ethernet:
    efa tenant service mirror session create –-name <session-name> --tenant <tenant-name>
               --source {<device-ip>,<eth | po | vlan>,<if-name>}
               --type {<source-device-ip>,<eth | po | vlan>,<source-if-name>:<port-based | flow-based>}
               --destination {<source-device-ip>,<eth | po | vlan>,<source-if-name> :
    	                     <destination-device-ip>,<eth | po | vlan>,<destination-if-name}
               --destination-type {<source-device-ip>,< eth | po | vlan>,<source-if-name>:<span>}
               --direction {<source-device-ip>,< eth | po | vlan>,<source-if-name> : <tx | rx | both>}
    (efa:root)root@node-2:~# efa tenant show
    |     Name     |  Type   | VLAN Range | L2VNI Range | L3VNI Range | VRF Count | Enable BD |         Ports         |  Mirroring Ports    |
    | sharedTenant | shared  |            |             |             |     0     |   false   |                       | 10.20.246.15[0/31]  |
    |              |         |            |             |             |           |           |                       | 10.20.246.16[0/31]  |
    |              |         |            |             |             |           |           |                       | 10.20.246.21[0/31]  |
    |              |         |            |             |             |           |           |                       | 10.20.246.22[0/31]  |
    |              |         |            |             |             |           |           |                       | 10.20.246.25[0/31]  |
    |              |         |            |             |             |           |           |                       | 10.20.246.26[0/31]  |
    |     ten1     | private |   11-20    |             |             |    10     |   false   | 10.20.246.15[0/1-10]  |                     |
    |              |         |            |             |             |           |           | 10.20.246.16[0/1-10]  |                     |
    |     ten2     | private |   21-30    |             |             |    10     |   false   | 10.20.246.15[0/11-20] |                     |
    |              |         |            |             |             |           |           | 10.20.246.16[0/11-20] |                     |
    (efa:root)root@node 2:~# efa tenant po show
    |   Name  | Tenant | ID |  Speed  | MTU | Negotiation | Min Link |  Lacp   |        Ports      |    State   |  Dev State  |  App State  |
    |         |        |    |         |     |             |   Count  | Timeout |                   |            |             |             |
    | ten1po1 | ten1   |  2 |  10Gbps |     |    active   |    1     |   long  | 10.20.246.15[0/1] | po-created | provisioned | cfg-in-sync |
    |         |        |    |         |     |             |          |         | 10.20.246.16[0/1] |            |             |             |
    | ten2po1 | ten2   |  3 |  10Gbps |     |    active   |    1     |   long  | 10.20.246.15[0/11]| po-created | provisioned | cfg-in-sync |
    |         |        |    |         |     |             |          |         | 10.20.246.16[0/11]|            |             |             |
    Example:
    10.20.246.15
    efa tenant service mirror session create --name ten1mirrorsession1 --tenant ten1
                        --source 10.20.246.15,po,ten1po1
                        --type 10.20.246.15,po,ten1po1:port-based
                        --destination 10.20.246.15,po,ten1po1:10.20.246.15,eth,0/31
                        --destination-type 10.20.246.15,po,ten1po1:span
                        --direction 10.20.246.15,po,ten1po1:both
    10.20.246.16
    efa tenant service mirror session create –name ten1mirrorsession2 --tenant ten1
                      --source 10.20.246.16,po,ten1po1
                      --type 10.20.246.16,po,ten1po1:port-based
                      --destination 10.20.246.16,po,ten1po1:10.20.246.16,eth,0/31
                      --destination-type 10.20.246.16,po,ten1po1:span
                      --direction 10.20.246.16,po,ten1po1:both
    10.20.246.15
    efa tenant service mirror session create –name ten2mirrorsession1 --tenant ten2
                    --source 10.20.246.15,po,ten2po1
                    --type 10.20.246.15,po,ten2po1:port-based
                    --destination 10.20.246.15,po,ten2po1:10.20.246.15,eth,0/31
                    --destination-type 10.20.246.15,po,ten2po1:span
                    --direction 10.20.246.15,po,ten2po1:both
    10.20.246.16
    efa tenant service mirror session create –name ten2mirrorsession2 --tenant ten2
                     --source 10.20.246.16,po,ten2po1
                     --type 10.20.246.16,po,ten2po1:port-based
                     --destination 10.20.246.16,po,ten2po1:10.20.246.16,eth,0/31
                     --destination-type 10.20.246.16,po,ten2po1:span
                     --direction 10.20.246.16,po,ten2po1:both
  2. Verify the switch configuration on the SLX device.
    10.20.246.15
    SLX# show running-config monitor session
    monitor session 1
     source port-channel 2 destination ethernet 0/31 direction both
    !monitor session 2
     source port-channel 3 destination ethernet 0/31 direction both
    SLX# show monitor session 1
    Session                 : 1
    Type                    : SPAN
    Description             : [None]
    State                   : Enabled
    Source Interface        : Po 2 (Down)
    Destination Interface   : Eth 0/31 (Down)
    Direction               : Both
    Type                    : port-based
    SLX# show monitor session 2
    Session                 : 2
    Type                    : SPAN
    State                   : Enabled
    Source Interface        : Po 3 (Down)
    Direction               : Both
    Type                    : port-based
    10.20.246.16
    monitor session 1
    !monitor session 2
    Session                 : 1
    Type                    : SPAN
    State                   : Enabled
    Direction               : Both
    Type                    : port-based
    Session                 : 2
    Type                    : SPAN
    State                   : Enabled
    Direction               : Both
    Type                    : port-based
