Extreme Networks
Extreme SLX-OS Management Configuration Guide, 20.4.2 > Guest OS for TPVM > VM Access Management > Extreme SLX-OS VM Access Management >
Published September 2022
Search this documentPrint this pageEmail this pageView PDFPreviousNext
  • Preface
    • Text Conventions
    • Documentation and Training
    • Help and Support
    • Send Feedback
  • About This Document
    • What‘s New in this Document
    • Supported Hardware
    • Regarding Ethernet interfaces and chassis devices
  • Configuration Fundamentals
    • Configuration Files
      • Auto-Persistence of Configuration Data
      • Displaying configurations
      • Backing up a running configuration
        • Applying previously saved configuration changes
      • Backing up configurations
        • Copying a configuration file to an external host
        • Backing up the startup configuration to a USB device
      • Configuration restoration
        • Restoring the default configuration
      • Tracking Configuration Changes
        • Turning off tracking of configuration changes
      • Managing flash files
        • Viewing the contents of a file in the flash memory
      • Rebooting the device
      • Copying Support Save Files
    • Session connection
      • Telnet
        • Connecting to an Extreme device with Telnet
        • Connecting to a remote device with Telnet
        • Enable or Disable Telnet service
      • SSH
        • Feature support for SSH
        • Connecting to an Extreme device with SSH
        • Connecting to a remote server with SSH
        • Managing SSH Client Public Keys
        • Enable or Disable SSH Service
      • Configuring the terminal session parameters
      • Configuring a login banner
    • Ethernet management interfaces
      • Configuring a static ethernet address
      • Displaying the management interface
      • Redundant Management Interface
        • Configure Redundant Management
        • Configure Redundant Management with a Mellanox Adapter
      • Force 1G connection speed on physical interfaces
    • Configuring an IPv6 address on the SLX platform
    • Port management
      • SLX 100G ports
      • Configuring breakout mode
      • 10G/1G auto negotiation and auto detection mode
      • Port flap dampening
        • Configuring port flap dampening
      • Port transition hold timer
        • Configuring the port transition hold timer
      • Link fault signaling
        • Configuring link fault signaling
    • Interface Ethernet ports
      • Displaying device interfaces
    • Interface reload delay to prevent traffic black-holing in vLAG
    • Chassis and host names
      • Customizing chassis and host names
    • System clock
      • Setting the clock
    • Management VRFs
      • VRF reachability
        • VRF reachability for device-initiated services
        • VRF reachability for server-based services
        • Telnet, HTTP, and SSH limitations and considerations
    • Heartbeat between SLX and EFA
      • Heartbeat Setting
    • Zero Touch Provisioning
      • Using ZTP
      • ZTP configuration
      • Example of ZTP in a two-node topology
    • MAC address aging
    • TCAM application-resource monitoring
    • Hardware profiles
      • TCAM profiles
        • Specifying a TCAM profile
      • TCAM sharing
        • Enabling TCAM sharing
      • Counter profiles
        • Specifying a counter profile
      • FIB compression
        • Configuring FIB compression
      • Border profiles for Internet peering
        • Configuring support for border profiles
      • Hardware profile show commands
    • Enter Maintenance Mode Before Performing Device Maintenance
    • Rebooting into Maintenance Mode
    • Support for OpenConfig Telemetry
      • OpenConfig-Interface YANG Module
      • OpenConfig-BGP Yang Module
      • OpenConfig-Platform Yang Module
      • Enabling OpenConfig Telemetry Support
      • Securing OpenConfig Telemetry Connections
      • Importing gNMI Server Private Key and Server Certificate
      • Importing gNMI Client CA Root Certificate
    • Static Prefix Independent Convergence
        • Configuring Static PIC
  • SLX-OS and Linux Shell Interoperability
    • Overview
      • Limitations
    • Executing Linux shell commands from SLX-OS
    • Executing scripts from SLX-OS
    • Accessing the Linux shell from SLX-OS
    • Executing SLX-OS commands from the Linux shell
    • Escalating Linux permissions to root
    • Saving and appending show command output to a file
    • Logs of Linux shell activities
      • Configuring remote logging of Linux shell activities
  • Guest OS for TPVM
    • VM Access Management
      • Extreme SLX-OS VM Access Management
        • Default credentials for the hosts
        • VM access
        • SLX-OS CLI to VM access
        • Serial Console Access
        • Serial console to VM access
        • TPVM Console Access
        • TVPM address assignment
    • Insight Interface and TPVM
      • Insight interface port-channel
      • TPVM on the SLX 9150 series
      • Configuring the Insight Interface for the SLX 9150/9250
      • Insight interface
        • Insight interface supported features
        • Insight Interface Data Path
        • Configure the Insight Interface SLX Endpoint
        • Configure the Insight Interface TVPM Endpoint for Analytic Mirroring
        • Configure the Insight Interface TVPM Endpoint for Routing
        • Configure the Insight Interface TVPM Endpoint for Switching
      • Inbound ACL-based mirroring
        • Enabling ACL-based port mirroring
        • Configuring inbound ACL-based mirroring to the insight interface
      • Insight interface traffic management and QoS
        • QoS egress scheduling
        • QoS rate shaping
      • Configuring QoS egress scheduling
      • Troubleshooting port-mirroring
        • SLX-OS VM commands
    • TPVM
      • Supported third-party applications, packages, and hardware
        • perfSONAR
        • ARP sponge
      • TPVM Management
        • TPVM Package Information
        • Using the tpvm command
        • Using the tpvm config Command
        • Using tpvm deploy
        • Upgrading TPVM
        • Uninstalling TPVM completely
      • Docker containers
      • Linux containers
      • Utilities installation and management
      • Assigning a static IP address on the TPVM Linux OS
      • Update TPVM Gateway
    • TPVM Configuration Persistence
      • How it Works
      • Deploy with TPVM Configuration Persistence
      • Managing Snapshots
      • Upgrading TPVM
      • TPVM Migration
      • Remove TPVM on Copying Default Config as Startup Config
      • Restoring Configuration from Backup File
  • Measured Boot
    • Measured Boot
    • Verifying Measured Boot
  • Remote Attestation
    • Configure Remote Attestation
  • Network Time Protocol (NTP)
    • Network Time Protocol overview
      • Network Time Protocol Server Overview
      • Network Time Protocol Client Overview
      • Network Time Protocol Associations
      • Network Time Protocol Authentication
    • Configuring NTP
    • Authenticating an NTP server
    • Displaying the active NTP server
  • SNMP
    • SNMP overview
      • Basic SNMP operation
      • SNMP community strings
      • SNMP groups
      • SNMP users
      • SNMP views
      • SNMP server hosts
      • SNMP Engine ID
      • Multiple SNMP server context to VRF mapping
      • SNMP source interface
    • Configuring SNMPv2
    • Configuring SNMPv3
    • Configuring an SNMP server context to a VRF
    • Offline SNMP ifIndex generation tool
      • Generating ifIndexes for various interfaces
      • Configuration examples for generating ifIndexes offline
  • LLDP
    • LLDP overview
      • Layer 2 topology mapping
      • LLDP configuration guidelines and restrictions
    • Configuring and managing LLDP
      • Understanding the default LLDP
      • Disabling LLDP globally
      • Configuring LLDP global parameters
      • Configuring LLDP profiles
      • Configuring an LLDP profile to an interface
      • Displaying LLDP information
      • Clearing LLDP-related information
  • Account and Password Recovery
    • Recover the admin password from the root account
    • Root account and password recovery
      • (DNX devices) Recover the root login account
      • (XGS devices) Recover the root login account
      • (DNX devices) Recover the root password
      • (XGS devices) Recover the root password
    • Force Password Change At First Login
    • Force Password Age Out
    • Configure an account to disable automatically
    • Configure an account with inactivity warning
  • Python Event-Management and Scripting
    • Python under Extreme operating systems
      • Python overview
      • Working interactively in the Python shell
    • Python scripts
      • Guidelines for writing Python scripts
      • Testing Python-script statements
      • Copying Python files to the device
        • Copying a file from a USB device
        • Downloading a file from a network
      • Running Python scripts from the command line
      • Python scripts and run-logs
        • Script illustrating the .get_output function (get_output.py)
        • Event-handler script
    • Python event-management
      • Configuring an event-handler profile
      • Activating an event-handler
      • Configuring event-handler options
    • Troubleshooting event-management
      • Aborting an event-handler action
    • Event-management show commands
  • Configuration Rollback
    • Configuration rollback overview
    • Configuration rollback details
    • Configuration rollback considerations and limitations
    • Configuring rollback
9037566-00 Rev AA
  • © 2024 Extreme Networks.
  • Legal
  • Privacy and Cookies Policy
