Disabling LLDP globally
LLDP is enabled globally by default. You can disable LLDP globally without changing any other aspect of the LLDP configuration.
To globally disable LLDP, perform the following steps:
  1. From privileged EXEC mode, access global configuration mode.
    device# configure terminal
  2. Access LLDP configuration mode.
    device(config)# protocol lldp
  3. Disable LLDP globally.
    device(config-lldp)# disable
  4. Verify the configuration.
    device(config-lldp)# do show running-config protocol lldp
    protocol lldp
     system-description Extreme BR-SLX9540 Router
     disable
The following configuration is an example of the previous steps to disable LLDP.
What to do next
If required, re-enable LLDP.
device(config-lldp)# no disable
