SNMP Engine ID
On the Extreme device, the SNMP Engine ID can be configured as either a 12 byte or 13 byte ID. It is also now possible to view the default SNMP Engine ID through the CLI show run command. Manually configured SNMP Engine ID are also reflected within the running configuration.
SNMP agent Engine ID can be 12 or 13 bytes in hexadecimal format. Each byte must be separated by colons. When using a 12 byte engine ID, each byte must be entered as 2 char per octet. For example, the value 1 must be entered as 01. However, for the 13 byte engine ID, each byte can be entered as 1 or 2 char per octet. For example, the value 1 can be entered as 1 or as 01.
Note the following when working with SNMP Engine ID:
A reboot is necessary for the configured engine ID to become active.
Use the no form of the command to remove the configured engine ID from database.
