Enabling TCAM sharing
Follow these steps to enable TCAM sharing.
  1. Enter global configuration mode.
    device# configure terminal
  2. Enter the hardware command to enable hardware configuration mode.
    device(config)# hardware
  3. Enter the profile tcam command to specify the TCAM-sharing profile or profiles that you require.
    device(config-hardware)# profile tcam cam-share l3-v4-ingress-acl l3-v6-ingress-acl
