Configuring Static PIC
To configure Static Prefix Independent Convergence, do the following:
  1. Navigate to the Configuration Mode.
    SLX # configure terminal
    SLX (config) #
  2. Execute the prefix-independent-convergence-static command to enable Static PIC.
    SLX (config)#prefix-independent-convergence-static
    SLX (config)#
    %Warning: Please run "clear ip[v6] route all vrf <vrf name>" for all static routes configured in VRFs
  3. Exit out of the Configuration Mode.
    SLX (config)# exit
    SLX #
Results
When configured, if there is a link fail, the traffic is switched over ICL to the configured backup Border Leaf.
This example configures Static PIC.
SLX (config)# prefix-independent-convergence-static
SLX (config)#
