In some scenarios, it is desirable that connections on a specific interface be restricted to a lower speed than the maximum supported speed. Such scenarios occur when the device that is connected to the interface is unable to connect at the highest speed possible for that interface.
This speed setting is only supported on the 1G/10G copper ports (ports 1-48) of the SLX 9150-48XT and Extreme 8520-48XT devices to enable the user to force 1000Mbps (1G) speed setting on these interfaces in both full-duplex and half-duplex mode. The master/slave setting allows the interface to act as either a clock master or a slave in the forced speed setting.
The following speed configurations are available:
1000-auto-full-duplex
1000-master-full-duplex
1000-master-half-duplex
1000-slave-full-duplex
1000-slave-half-duplex
The 1000-auto-full-duplex command enables the configuration of the ports to be set at 1G speed and in full duplex mode.
To reset the above setting to the default setting of 1G/10G AN mode, use either the speed auto or the no speed command.
If the local port is configured as 1000-master-full-duplex, then the peer port must be configured as 1000-slave-full-duplex.
If the local port is configured as 1000-slave-half-duplex, then the peer port must be configured as 1000-master-half-duplex.
If the local port is configured as 1000-auto-full-duplex, then the peer port must be configured for auto-negotiation for the link to be established.
The show interface ethernet command is also enhanced to show the configured speed for the interface.
SLX(conf-if-eth-0/1-2)# do show interface ethernet 0/1 Ethernet 0/1 is up, line protocol is up (connected) Hardware is Ethernet, address is f064.26f2.d80c Current address is f064.26f2.d80c Fixed Copper RJ45 Media Present Interface index (ifindex) is 201334784 (0xc002000) MTU 9216 bytes Maximum Speed : 10G LineSpeed Actual : 1000 Mbit LineSpeed Configured : 1G forced master, Duplex: Half Priority Tag disable Forward LACP PDU: Disable Route Only: Disabled
The following example displays the forced 1G configuration on the Extreme 8520-48XT device
8520-48XT# show interface ethernet 0/36 Ethernet 0/36 is up, line protocol is up (connected) Hardware is Ethernet, address is f064.26f4.4c2f Current address is f064.26f4.4c2f Fixed Copper RJ45 Media Present Interface index (ifindex) is 201621504 (0xc048000) MTU 9216 bytes Maximum Speed : 10G LineSpeed Actual : 1000 Mbit LineSpeed Configured : 1G auto full, Duplex: Full Priority Tag disable Forward LACP PDU: Disable Route Only: Disabled
The following example how to configure the Force 1G speed configuration on an Extreme 8520-48XT device.
8520-48XT(config)# interface Ethernet 0/36 8520-48XT(conf-if-eth-0/36)# speed ? Possible completions: 100 100Mbps 1000 1Gbps 1000-auto 1Gbps AN (802.3 Clause 37 Auto-Negotiation) 1000-auto-full-duplex 1Gbps Auto Negotiation for copper cable 1000-master-full-duplex 1Gbps - Set as Master with Full Duplex 1000-master-half-duplex 1Gbps - Set as Master with Half Duplex 1000-slave-full-duplex 1Gbps - Set as Slave with Full Duplex 1000-slave-half-duplex 1Gbps - Set as Slave with Half Duplex 10000 10Gbps 25000 25Gbps 40000 40Gbps 100000 100Gbps auto Auto Detection (default) 8520-48XT(conf-if-eth-0/36)# speed 1000-auto-full-duplex 8520-48XT(conf-if-eth-0/36)# no shutdown 8520-48XT(conf-if-eth-0/36)# end 8520-48XT# show running-config interface Ethernet 0/36 interface Ethernet 0/36 speed 1000-auto-full-duplex no shutdown ! 8520-48XT#
