If the root account is disabled and SLX-OS CLI is not available, recover the root login
account.
For a list of the currently supported XGS
devices, see the "Supported Hardware" topic.
Enter the
reboot command.
Select and enter the
ONIE option.
Select and enter the ONIE: Rescue option.
Define the root login value for the root recover environment variable.
ONIE:/ # bootenv VM_Root_Recover RootLogin
Enter the reboot command.
ONIE:/ # reboot
ONIE:/ # discover: Rescue mode detected. No discover stopped.
Stopping: dropbear ssh daemon... done.
The root account is now enabled. You can
log in with the default password.
If the SLX-OS CLI is available, you can recover the root account by using the
SLX-OS CLI root enable command.
