Supported Hardware
For instances in which a topic or part of a topic applies to some devices but not to others, the topic specifically identifies the devices.
SLX-OS 20.4.2 supports the following hardware platforms.
All configurations and software features that are applicable to SLX 9150 and SLX 9250 devices are also applicable for the Extreme 8520 and Extreme 8720 devices respectively.
The "Measured Boot with Remote Attestation" feature is only applicable to the Extreme 8520 and Extreme 8720 devices. It is not supported on the SLX 9150 and SLX 9250 devices.
Although many software and hardware configurations are tested and supported for this release, documenting all possible configurations and scenarios is beyond this document's scope.
For information about other releases, see the documentation for those releases.
