This topic describes the process to import the gNMI server's private key and server certificate in the pkcs format.
From within the SLX-OS context, run the cryto ca import-pkcs command and pass appropriate information for this command.
SLX #  crypto ca import-pkcs type pkcs12 cert-type gNMI-server directory
/root/certfolder/AV2 file av2.pfx host 10.x.x.x user root pass pass protocol SCP pkcs-passphrase pkcs
Results
The server certificate is imported and saved.
