If you are using ExtremeCloud IQ Controller to manage your network then you can use the Automatic Frequency Coordination (AFC) Explorer tool - also known as the AFC tool - to plan your AFC deployment.
With the AFC tool, you can:
Map out the expected coverage area.
Sample up to 40 locations within this area and assess expected AFC compliance, available frequencies, and authorized transmit power.
Visually display sampled points as pins on the map for analysis and planning.
For more information, see the AFC Explorer section of the ExtremeCloud IQ Controller v10.15.01 User Guide or later.
