Indoor Access Point 6GHz Standard Power Deployment Guide
Deployment
Deployment Planning
Confirm GPS Availability With AFC Mobile App
> Confirm GPS Availability With iOS Mobile App
Extreme Networks, Inc. October 01, 2026
Abstract
Preface
New in this Guide
Supported APs for AFC in Canada and the United States
Extreme Networks 6GHz Standard Power Solution
Indoor Use Cases for 6GHz Standard Power
Geo-Location Agent
AFC Mobile App
Supported Devices for Mobile App
Requirements for AFC Mobile App
AFC Mobile App Restrictions
Deployment
Deployment Workflow
Deployment Planning
AFC Explorer
Measure GPS Signal Strength
Site Floor Plan
Confirm GPS Availability With Android Mobile App
Configuration
ExtremeCloud IQ Configuration
ExtremeCloud IQ Controller Configuration
Set Anchor APs with AFC Mobile App
Set Anchor APs with iOS App
Set Anchor APs with Android App
Monitor and Troubleshoot
The 6GHz Standard Power Startup Process
Power Outages and Planned Outages
6GHz Radio Power AFC
Geo-location is Unavailable
ExtremeCloud IQ Troubleshoot and Monitor
Recalculate Geo-Location Co-ordinates
View AFC Geo-Location Floor Report
ExtremeCloud IQ Controller Troubleshoot and Monitor
ExtremeCloud IQ Controller Image Upgrade
AFC Glossary
6 GHz Standard Power
Automated Frequency Coordination (AFC)
AFC Service Provider
AFC Agent
Fine Time Measurement (FTM)
Fine Time Measurement (FTM) Ranging
Geo-Location Agent
Low Power Indoor (LPI)
Perform the following task if you have an iOS mobile device.
Login to the Mobile App.
ExtremeCloud IQ
- Login to the Cloud Network.
- Login to the Local Network.
The Geo Location window opens. If the Geo Location window does not open, then your phone does not support the Mobile App.
Select
Geolocation Set
Select
GPS Check
A confirmation window opens.
Grant the Mobile App access to your location.
Precise - Select for detailed location coordinates.
Approximate - Use for a general location co-ordinates.
While using the app - You will not have to grant access again.This is the recommended choice.
Only this time - A one-time access to your location. Select if you do not expect to use this feature often.
Don't allow - Blocks the app from accessing your location.
