Confirm GPS Availability With AFC Mobile App
You can confirm if a GPS signal is available in a location using the the ExtremeCloud IQ Mobile Companion app (AFC Mobile app). Use this tool before you deploy your APs so you can plan your AP locations. If a GPS signal is not available, then you will not be able to use the location for an anchor AP.
