Supported APs for AFC in Canada and the United States
The following APs are approved for AFC deployment in Canada and the United States. 6 GHz AFC is country dependent and is not available in every country.
The following table uses the term composite device. A composite device is an AP capable of operating in both Standard Power (SP) and Low Power Indoor (LPI).
Important
Important
6 GHz Standard Power is country dependent and is not available in every country.
Table 1. Supported APs
APIntegrated GPS Unit6GHz Low Power Indoor6GHz Standard Power
Outdoor APs
AP5060D and AP5060U YesNoYes
AP5050D YesNoYes
AP5050U YesNoYes
AP4060YesNoYes
AP4060XYesNoYes
AP3060YesNoYes
Indoor APs
If you deploy the following APs as anchor APs, then you will have to use the ExtremeCloud IQ Mobile Companion app (AFC Mobile app).
AP3000 NoYesYes
Only available on ExtremeCloud IQ Controller; 6GHz SP is not supported on ExtremeCloud IQ.
AP3000X NoYes
AP3020 /AP3020X NoYesYes
AP4000 NoYesYes
AP4020
(composite device)
NoYes
(Default)
Yes
AP4020X
(composite device)
NoYes
(Default)
Yes
AP4020FX NoNoYes
Important: Mandatory for US and Canada - AP4020FX must be deployed with indoor Automatic Frequency Coordination (AFC) only, due to the external antennas on the 6GHz ports. You must deploy with AFC to prevent external antennas from interfering with nearby deployments. AFC verifies your location, antenna type, and power settings, then identifies which channels and power levels are safe to use.
The AP4020FX (SKUs AP4020FX-WW and AP4020FX-WW-TAA) is only available in the USA and Canada because of the 6 GHz external ports.
AP5010 NoYesYes
AP5020
(composite device)
NoYesYes
AP5022, AP5022FX , and AP5022S6D NoYesYes
