The following workflow outlines the basic steps as you deploy your indoor 6GHz Standard Power access points.
| Step | Action | Purpose |
| 1. | Plan your deployment. | Prepare for AP placement. |
| 2. | Install the APs. |
Install the APs on site. Follow the installation instructions in the installation guide for your AP. Note: Place APs less than 20m (65.61 ft) apart for FTM 11mc AP-to-AP ranging connectivity. Each AP must be able to range to 3 other APs.
| 3. |
Site configuration ExtremeCloud IQ or ExtremeCloud IQ Controller. | Configure APs for Standard Power. |
| 4. | Monitor and troubleshoot. | Resolve any possible deployment issues. |
