Use the following workflow if you use ExtremeCloud IQ as your management option. For more information, see the ExtremeCloud IQ (Classic) v25.4.0 User Guide or later.
Before you begin your configuration, do the following:
Create a Site with Country set to United States or Canada.
Create a Floor Plan for each floor associated to the site. See Site Floor Plan.
| Step | Action | Purpose |
| 1. | Navigate to Radio Profiles and configure the Supported Power Modes to SP. You can also modify radio profile settings when you configure a device template. | You can use a 6GHz AP to operate at SP. AP drops to Low Power Indoors (LPI) if AFC spectrum authorization is unavailable. The default setting is LPI. Note: APs that support SP/LPI fallback operate in LPI power mode until they're assigned spectrum information. Then they transition to SP power mode. SP-only APs keep Wi-Fi2 radio Off until the spectrum information is assigned. Then the Wi-Fi2 radio turns On in SP power mode.
For more information, see "About Radio Profiles" in ExtremeCloud IQ (Classic) v25.4.0 User Guide or later. |
| 2. | Assign the AP to a 6GHz floor. | - |
| 3. | Assign the new SP mode radio profile to the AP. | - |
| 4. | Navigate to Network Policies and configure at least one SSIDs:
See "Configure the SSID for a Standard Wireless Network" in ExtremeCloud IQ (Classic) v25.4.0 User Guide or later. | Note the following:
The FTM policy is pushed to all APs within an indoor 6 GHz floor. |
| 5. | If you are using an anchor AP with an integrated GPS unit, then navigate to AFC Wireless View and set the AP as Anchor from the Actions. | Designates your anchor APs. Note: Anchor APs without a GPS unit must be set using the ExtremeCloud IQ Mobile Companion app
| 6. | (Optional) Navigate to the Site tab and customize the AFC Schedule Update. Toggle the parameter On and set the Hours and Minutes fields. | The default setting is 12:00 AM local time. The AFC service must be refreshed at least once every 24 hours to maintain authorization in compliance with AFC requirements. |
| 7. | If your anchor APs do not have integral GPS units, then have a co-worker go to the anchor points and configure the geo-coordinates using the AFC Mobile app. | Assigns geo-coordinates to the anchor APs. See Set Anchor APs with AFC Mobile App. |
| 8. | Go to the AFC Wireless page and monitor the AFC status. | After several minutes, the AP should report the AFC status, including the following information:
