Recalculate Geo-Location Co-ordinates
If you use ExtremeCloud IQ as your network management option, you can recalculate your Geo-Location co-ordinates. Perform this task if the Geo-Location status is Unavailable on the AFC Wireless page.
  1. Navigate Utilities > Tools.
  2. Select one of the following from the pull down menu:
    • Recalulate GPS Location - Choose this option if you want to recalculate the GPS co-ordinates for all APs on the floor.
    • Send AP Range Information- Choose this option if you want to request updated FTM ap-to-ap ranging information for all APs on the floor.
