Deployment Planning
The table below lists the minimum number of anchor APs for common deployment scenarios. For a list of supported APs, see Supported APs for AFC in Canada and the United States.
The following table lists the minimum number of anchor APs required for an AFC deployment. The number of anchor APs required for a deployment can vary based on the specific requirements and conditions of the deployment scenario. As a best practice, deploy more than the minimum to allow for better coverage.
Table 1. Minimum Number of Required Anchor APs
APsMinimum Number of Anchor APs
704
805
1006
1207
1408
1709
20010
22511
25012
Building properties often determine the degree of shielding blocking the GPS signal. Install anchor APs as close as possible to the building perimeter, such as on an outside wall or near an outside window. You should also choose the anchor AP's location based on the availability of the GPS signal. Determine the best anchor AP position by surveying the GPS signal with a smartphone application. See Measure GPS Signal Strength.
Plan also for the mounting height of each AP. The height must reflect the antenna height above ground and not the building floor. See Site Floor Plan
And finally, place APs less than 20m (65.61 ft) apart for FTM 11mc AP-to-AP ranging connectivity. Each AP must be able to range to 3 other APs.
