Configures the number of labels that are reserved for specifying the incoming label for static LSPs and static pseudowires.
| labels |
                 Specifies that labels are reserved to specify the incoming label for static LSPs and static pseudowires.  |
| max-static |
                 Specifies the number of labels that are reserved to specify the incoming label for static LSPs and static PWs.  |
| max_static-labels |
                 Specifies the value for the maximum number of static labels.  |
The default static label range size is 100.
Use this command to configure the number of labels that are reserved for specifying the incoming label for static LSPs and static PWs. The static label range generally starts at 16 and the default static label range size is 100. This means that the default static label range is 16 through 115 and can be allocated for either incoming (both transit and egress) static LSPs, or incoming static PWs. The maximum static label_range_size is equal to the incoming label table size – 100 labels for signaling. 960 labels are reserved for L3VPNs. The maximum number of labels available for static configuration is 7116, since at least 100 of those labels are reserved for dynamic signaling.
Since these values vary per-platform, use the show mpls label usage command to see details about label usage and platform capability. The minimum static label range size is 0.
MPLS must be disabled when issuing this command. If MPLS is enabled, an error message is displayed and the command has no affect. All other labels, including outgoing labels for static LSPs and PWs and signaled labels used by RSVP-TE and LDP, are allocated out of the dynamic label space.The following example illustrates how to configure MPLS max-static labels, and how to display them:
Summit1.2 # show mpls lab usage Label Type Size Label Range -------------------- ------- ---------------------------------------- Supported 1048576 0x00000 - 0xfffff (0 - 1048575) Reserved 16 0x00000 - 0x0000f (0 - 15) Static 100 0x00010 - 0x00073 (16 - 115) L3VPN 960 0x00074 - 0x00433 (116 - 1075) Dynamic 7116 0x00434 - 0x01fff (1076 - 8191) Internal Use 0 0x00000 - 0x00000 (0 - 0) ... Summit1.3 # disable mpls * Summit1.4 # conf mpls lab max-static 7117 Error: There must be at least 100 dynamic labels remaining for MPLS signalling protocols. * Summit1.5 # conf mpls lab max-static 7116 * Summit1.6 # show mpls lab usage Label Type Size Label Range -------------------- ------- ---------------------------------------- Supported 1048576 0x00000 - 0xfffff (0 - 1048575) Reserved 16 0x00000 - 0x0000f (0 - 15) Static 7116 0x00010 - 0x01bdb (16 - 7131) L3VPN 960 0x01bdc - 0x01f9b (7132 - 8091) Dynamic 100 0x01f9c - 0x01fff (8092 - 8191) Internal Use 0 0x00000 - 0x00000 (0 - 0) ...
This command was first available in ExtremeXOS 15.4
This command is available only on the platforms that support MPLS as described in the ExtremeXOS v33.2.1 Licensing Guide document.
