Unconfigures the IPv4 and IPv6 masks.
| port_list |
                 Specifies the ports.  |
N/A.
Use this command to remove masks for the IPv4 and IPv6 source and destination address fields on ports. These masks were defined using one or more of the following commands:
The following command removes a mask on port 2:1:
unconfigure ip-fix ports 2:1 flow-key mask
This command was first available in ExtremeXOS 12.5.
This command is available on ExtremeSwitching X435, X440-G2, X450-G2, X460-G2, X465, and X695 series switches.
