This command configures This command is available on the ExtremeSwitching X440-G2, X450-G2, X460-G2, and X465 series switches. port-level classification
power-up mode for Extreme Networks PoE devices that do not support 802.3bt when
connecting to switches with 60W/90W PoE ports. ExtremeSwitching platforms
support per-port basis configuration.
Syntax Description
classification
Classification power-up mode.
ports
Specifies the port.
port_list
Port list separated by a comma or - .
Default
N/A.
Usage Guidelines
This command restores port-level classification power-up mode to default based on
port type.
# show inline-power configuration ports 20-26
Port Config Operator Limit Priority Detection Classification Label
20 Enabled 60000 mW Low 802.3af-only 802.3pre-bt N
21 Enabled 60000 mW Low 802.3af-only 802.3bt-type3 N
22 Enabled 60000 mW Low 802.3af-only 802.3bt-type3 N
23 Enabled 45000 mW Low 2-point legacy-and-802.3af 802.3bt-type3 N
24 Enabled 60000 mW Low 802.3af-only 802.3at N x435-port10
25 Enabled 90000 mW Low 4-point legacy-and-802.3af 802.3pre-bt N
26 Enabled 90000 mW Low 802.3af-only 802.3bt-type3 N
This command was first available in ExtremeXOS 31.3.
Platform Availability
This command is available on ExtremeSwitching X435, X440-G2, X450-G2, X460-G2, X465, and X695 series switches.
ExtremeSwitching
X450-G2-24p-GE4—ExtremeXOS 16.1 and
later.
ExtremeSwitching
X450-G2-48p-GE4—ExtremeXOS 16.1 and
later.
ExtremeSwitching
X450-G2-24p-10GE4—ExtremeXOS 16.1 and
later.
ExtremeSwitching
X450-G2-48p-10GE4—ExtremeXOS 16.1 and
later.
ExtremeSwitching
X460-G2-24p-10GE4—ExtremeXOS 15.6 and
later.
ExtremeSwitching
X460-G2-48p-10GE4—ExtremeXOS 15.6 and
later.
ExtremeSwitching
X460-G2-24p-GE4—ExtremeXOS 15.6 and
later.
ExtremeSwitching
X460-G2-48p-GE4—ExtremeXOS 15.6 and
later.
ExtremeSwitching
X460-G2-16mp-32p-10GE4—ExtremeXOS 15.6 and
later.
ExtremeSwitching
X460-G2-24p-24hp-10GE4—ExtremeXOS 22.2 and
later.
ExtremeSwitching
X440-G2-48p-10GE4—ExtremeXOS 21.1 and
later.
ExtremeSwitching
X440-G2-24p-10GE4—ExtremeXOS 21.1 and later.
ExtremeSwitching
X440-G2-12p-10GE4—ExtremeXOS 21.1 and
later.
ExtremeSwitching X465-48P—ExtremeXOS 30.2 and later.
ExtremeSwitching
X435-8P-4S—ExtremeXOS 30.5 and
later.
ExtremeSwitching
X435-24P-4S—ExtremeXOS 30.5 and
later.
ExtremeSwitching
X435-8P-2T-W—ExtremeXOS 30.5 and
later.
ExtremeSwitching X465-24MU-24W—ExtremeXOS 30.2 and later.
ExtremeSwitching X465-48W—ExtremeXOS 30.2 and later.
ExtremeSwitching X465-24MU—ExtremeXOS 30.2 and later.
ExtremeSwitching X465-24W—ExtremeXOS 30.2 and later.
ExtremeSwitching
X465i-48W—ExtremeXOS 30.5 and later.
