Displays Automation Edge remote VXLAN network identifier (VNI)-device database information.
| automation | Displays Automation Edge VXLAN VNI-device database information. |
| edge | Specifies Automation Edge. |
| database | Specifies Automation Edge database information. |
N/A.
N/A.
The following example shows database information:
# show automation edge database Database Name Status ------------- ------ SampleDB Up Database Name Status ------------- ------ SampleDB Down
This command was first available in ExtremeXOS 31.1 as a demonstration feature.
This command is fully supported in ExtremeXOS 31.2.
This command is available on ExtremeSwitching X465, X695 series switches.
