This procedure only applies to VSP 8400 Series, VSP 4900 Series, and 5520 Series.
Use the following procedure to create a MACsec Key Agreement (MKA) profile. Creating an MKA profile changes the CLI command mode to mka profile mode.
You can also use this procedure to enter mka profile CLI command mode for an existing MKA profile.
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#macsec mka profile extreme19 Switch:1(mka-profile)#
The following table defines parameters for the macsec mka profile command.
Variable |
Value |
WORD<1-16> |
Specifies the MKA profile name. An MKA profile name consists only of alphanumeric characters (0-9, A-Z, and a-z). The profile name is case sensitive. |
