BFD for IPv6 interfaces is a demonstration feature on some products. For more information about feature support, see VOSS Feature Support Matrix.
Use the following procedure to display BFD configuration on an IPv6 interface.
The following example displays port configuration information for BFD.
Switch:1>show ipv6 bfd interfaces gigabitethernet 1/3
Port Bfd
PORT STATUS MIN_RX INTERVAL MULTIPLIER VRF-ID
1/3 enable 200 200 3 0
The following table defines parameters for the show ip bfd interfaces command.
Variable |
Value |
{slot/port[/sub-port][-slot/port[/sub-port]][,...]} |
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
<1-4059> |
vrf WORD<1-16> |
Specifies a VRF instance by VRF name. |
vrfids WORD<0-512> |
Specifies a VRF or range of VRFs by ID. |
