You can use the navigation pane to see what commands are available and to quickly browse through the command hierarchy. A row of buttons at the top of the navigation pane provides a quick method to perform common functions.
For module-based chassis, menu options related to a specific module are activated only after you install and select the required module.
The following table describes the buttons that display at the top of the navigation pane.
Button |
Name |
Description |
Save Config |
Saves the running configuration. |
Refresh Status |
Refreshes the Device Physical View. |
Edit |
Edits the selected item in the Device Physical View. |
Graph |
Opens the graph options for the selected item in the Device Physical View. |
Help Setup Guide |
Opens instructions about how to install the Help files and configure EDM to use the Help files. |
Expand a folder by clicking it. Some folders have subfolders such as the Edit folder, which has the Port, Diagnostics, and other subfolders.
Within each folder and subfolder menu, there are numerous options, which provide access to tabs. To open an option, select it. The selected tab dispalys in the menu bar and opens in the content pane. The following table describes the main folders in the navigation pane.
Menu |
Description |
Device |
Use the Device menu to refresh and update device information or enable polling.
VRF Context view |
Use the VRF Context view to switch to another VRF context when you use the embedded EDM. GlobalRouter is the default view at log in. You can configure both Global Router (GRT) and Virtual Routing and Forwarding (VRF) instances when you launch a VRF context view. You can open only five tabs for each EDM session. |
Edit |
Use the Edit menu to view and configure parameters for the chassis hardware or for the currently selected object. The selected object can be one or more ports. You can also use the Edit menu to perform the following tasks:
Graph |
Use the Graph menu to view and configure EDM statistics and to produce graphs of the chassis or port statistics. |
Power Management |
Use the Power Management menu to view and configure Energy Saver. |
VLAN |
Use the VLAN menu to view and configure VLANs, spanning tree groups (STG), MultiLink Trunks/LACP, SMLT, and SLPP. |
IS-IS |
Use the IS-IS menu to view and configure IS-IS, Shortest Path Bridging MAC (SPBM), statistics, I-SIDs, and Multi-area SPB. |
VRF |
Use the VRF menu to view and create VRFs. |
IP |
Use the IP menu to view and configure IP routing functions for the system, including the following:
IPv6 |
Use the IPv6 menu to view and configure IPv6 routing functions, including the following:
Security |
Use the Security menu to view and configure access policies, ACL filters, certificates, and features such as RADIUS, RADIUS CoA, SSH, IPSec, TACACS+, and EAPoL. |
QOS |
Use the QOS menu to view and configure mapping tables, QoS port states, CoS Queue Stats, and Queue Profiles. |
Serviceability |
Use the Serviceability menu to enable, configure, or view:
