View ACE Statistics
View ACE statistics to ensure that the filter operates correctly.
The ACL statistics do not support security action on some hardware platforms.
View ACE statistics:
Based on your hardware platform, the output can display all the ACL packets or segregate them as QoS and security ACL packets.
Switch:1>enable
Switch:1#show filter acl statistics all
Acl Global Statistics Table
Acl Id Acl Name Acl Type Acl Sec Acl Sec Acl QOS Acl QOS Acl Acl
Packets Bytes Packets Bytes Packets Bytes
1 ACL-1 inVlan 0 0 0 0 0 0
2 ACL-2 inVlan 0 0 0 0 0 0
Displayed 2 of 2 entries
Acl Default Statistics Table
Switch:1#show filter acl statistics default
Switch:1#show filter acl statistics global 2
Displayed 1 of 1 entries
View filter acl ace policer statistics on VSP 7400 Series, 5420 Series, and 5520 Series:
IPv4 policer statistics for red, yellow, and green packets are available on VSP 7400 Series, 5420 Series, and 5520 Series. Statistics display as numbers, which represent the hit number of packets and bytes.
Switch:1#show filter acl statistics 3 3 policer
Acl Ace Policer Table
Acl Id Ace Id Packets Bytes Green Green Yellow Yellow Red Red
3 3 29964026 106591916 142584 14254 142574 277225 28869904 10275810600
View filter acl ace policer statistics on VSP 4900 Series.
Only IPv4 policer statistics for red packets are available on VSP 4900 Series. Yellow and green packet counters are not supported on VSP 4900 Series. Statistics display as numbers, which represent the hit number of packets and bytes.
Switch:1(config)#show filter acl statistics 3 3 policer
3 3 29964026 106591916 N/A N/A N/A N/A 28869904 10275810600
The show filter acl statistics <acl-id> <ace-id> policer command displays statistics according to the configuration on the switch.
View filter acl ace statistics with no policer configured.
10 1001 0 0 N/A N/A N/A N/A N/A N/A
View filter acl ace statistics with filter ACE enabled and policer configured, but the filter is not hit or there is no traffic running.
Switch:1(config)#show filter acl statistics 10 1011
3 3 0 0 0 0 0 0 0 0
View filter acl ace statistics with filter ACE not enabled and policer not configured
Use the data in the following table to use the show filter acl statistics command.
Variable |
Value |
<acl-id> |
Specifies the ACL ID. Use the CLI Help to see the available range for the switch. |
<ace-id> |
Specifies the ACE ID. Different hardware platforms support different ACE ID ranges. Use the CLI Help to see the available range for the switch. |
policer
Note:
Exception: only supported on VSP 4900 Series, VSP 7400 Series, 5520 Series, and 5420 Series. |
Specifies the policer parameter for the command. |
