This procedure only applies to VSP 8400 Series, VSP 4900 Series, and 5520 Series.
The MKA participant with the highest actor priority is designated as the key server.
Apply an MKA profile to the port.
Disable MKA on the port before you configure a value for actor priority. Enable MKA on the port after you configure an actor priority value.
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#interface gigabitethernet 1/4 Switch:1(config-if)#macsec actor-priority 0x0f
The following table defines parameters for the macsec actor-priority command.
Variable |
Value |
<0x00-0xff> |
Specifies a hexadecimal value for actor priority, which determines key server selection. Lower values indicate a higher priority. The default is 10. |
{slot/port[/sub-port] [-slot/port[/sub-port]] [,...]} |
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
