    enable
    configure terminal
  2. Configure the key-exchange to use:
    ssh key-exchange-method {[diffie-hellman-group1-sha1] [diffie-hellman-group14-sha1] [diffie-hellman-group-exchange-sha256]}
The following table defines parameters for the ssh key-exchange-method command.
Variable Value
[diffie-hellman-group1-sha1][diffie-hellman-group14-sha1][diffie-hellman-group-exchange-sha256]
Note:
Exception: diffie-hellman-group1-sha1 is only supported on VSP 8600 Series.
Exception: diffie-hellman-group-exchange-sha256 is not supported on VSP 8600 Series.
Configures the key-exchange method. Select a key-exchange method from one of the following:
  • diffie-hellman-group1-sha1
  • diffie-hellman-group14-sha1
  • diffie-hellman-group-exchange-sha256
