This procedure only applies to VSP 8400 Series, VSP 4900 Series, and 5520 Series.
Use the following procedure to display information about all MKA profiles configured on the switch. Optionally, you can view information about a specific MKA profile.
The following example displays MACsec MKA profile information:
Switch:1#show macsec mka profile
MACsec MKA Profile
Profile Profile Cipher Confidentiality Replay Window Port Include-SCI
Name Id Suite Offset Protect Size
test030519 1 gcm-aes-128 30 Enabled 200 1/3 false
test031519 2 gcm-aes-128 50 Enabled 225 1/4 false
test032019 3 gcm-aes-128 30 Enabled 240 2/2 false
All 3 out of 3 Total Num of MACsec MKA Profiles displayed
The following example displays MACsec MKA information for a specific profile.
Switch:1#show macsec mka profile test030519
MACsec MKA Profile
The following table defines parameters for the show macsec mka profile command.
| Variable | Value |
WORD<1-16> |
Specifies the MKA profile name. An MKA profile name can consist only of alphanumeric characters (0-9, A-Z, and a-z). The profile name is case sensitive. |
