Verify the boot configuration flags to verify boot configuration settings. Boot configuration settings only take effect after you reset the system. Verification of these parameters is essential to minimize system downtime and the resets to change them.
enable
show boot config flags
Flag support can vary across hardware models.
Switch:1#show boot config flags flags advanced-feature-bandwidth-reservation low flags block-snmp false flags debug-config false flags debugmode false flags dvr-leaf-mode false flags enhancedsecure-mode false flags factorydefaults false flags flow-control-mode true flags ftpd true flags ha-cpu true flags hsecure false flags ipv6-egress-filter true flags ipv6-mode false flags linerate-directed-broadcast false flags logging true flags macsec false flags nni-mstp false flags reboot true flags rlogind false flags savetostandby true flags spanning-tree-mode mstp flags spbm-config-mode true flags sshd true flags syslog-rfc5424-format true flags telnetd true flags tftpd true flags trace-logging false flags urpf-mode true flags verify-config true flags vrf-scaling true flags vxlan-gw-full-interworking-mode false
