This procedure only applies to VSP 8400 Series, VSP 4900 Series, and 5520 Series.
Use the following procedure to configure replay protect for an MKA profile. Replay protect provides a configurable window that accepts a specified number of out-of-sequence frames.
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#macsec mka profile test030519 Switch:1(mka profile)#replay-protect enable window-size 200
The following table defines parameters for the replay-protect command.
Variable |
Value |
enable |
Enables replay protection on an MKA profile. The default is disabled. |
window-size <5-500> |
Specifies the maximum acceptable difference in packet ID numbers between out of order packets. If a packet ID number differs from the ID number of the previously received packet by more than the specified window size, the packet is dropped. |
WORD<1-16> |
Specifies the MKA profile name. An MKA profile name consists only of alphanumeric characters (0-9, A-Z, and a-z). The profile name is case sensitive. |
