Use the following procedure to configure SCI tagging on a MACsec-enabled switch. The default is enabled.
The configuration should be the same at both ends of the link, either enabled or disabled.
If you are running VOSS 8.4.2 or earlier, disable SCI tagging on the switch.
This procedure only applies to VSP 8400 Series, VSP 4900 Series, and 5520 Series.
enable
configure terminal
macsec mka profile WORD<1-16>
no include-sci enable
default include-sci enable
