View information about OSPF to view the current configuration.
Switch:1#show ipv6 ospf
OSPFv3 Global Information - GlobalRouter
router-id : 170.76.84.0
admin-state : DISABLE
version : 3
area-bdr-rtr-state : FALSE
as-bdr-rtr-state : FALSE
helper-mode : ENABLED
as-scope-lsa-count : 0
lsa-checksum : 0
originate-new-lsas : 0
rx-new-lsas : 0
ext-lsa-count : 0
default-metric :
ethernet - 100
fast-ethernet - 10
gig-ethernet - 1
ten-gig-ethernet - 1
forty-gig-ethernet - 1
vlan - 10
Switch:1>show ipv6 ospf area
OSPF Area - GlobalRouter
AREA_ID STUB_AREA NSSA IMPORT_SUM TRANS_ROLE TRANS_STATE
0.0.0.0 false false true always disabled
STUB_METRIC STUB_METRIC_TYPE SPF_RUNS BDR_RTR_CNT ASBDR_RTR_CNT LSA_CNT LSACK_SUM
10 ospfV3Metric 0 0 0 0 0
Switch:1#show ipv6 ospf interface
Total ospf areas: 1
Total ospf interfaces: 2
OSPF Interface - GlobalRouter
IFINDX(VID/BRT) AREAID ADM IFSTATE METRIC PRI DR/BDR IFTYPE
331 (5/12 ) 0.0.0.0 ena DOWN 1 1 0.0.0.0 PT-PT
0.0.0.0 lnklsaSup
2078 (30 ) 0.0.0.0 ena DR 1 1 197.146.128.0 BROADCAST
0.0.0.0
2 out of 2 Total Num of ospf interfaces displayed
Total ospf virtual interfaces: 0
OSPF Virtual Interface - GlobalRouter
AREAID NBRIPADDR STATE
0 out of 0 Total Num of ospf virtual interfaces displayed
Switch:1#show ipv6 ospf int-timers
OSPF Interface Timers - GlobalRouter
TRANSIT RETRANS HELLO DEAD POLL
IFINDX(VID/BRT) AREAID DELAY INTERVAL INTERVAL INTERVAL INTERVAL
2059 (11 ) 0.0.0.0 1 5 10 40 120
2060 (12 ) 0.0.0.0 1 5 10 40 120
OSPF Virtual Interface Timers - GlobalRouter
AREAID NBRIPADDR DELAY INTERVAL INTERVAL INTERVAL
Switch:1#show ipv6 ospf neighbor
OSPF Neighbor - GlobalRouter
IFINDX(VID/BRT) NBRROUTERID NBRIPADDR STATE TTL
331 (10/19) 97.146.128.0 fe80:0:0:0:2ef4:c5ff:fe92:8a00 Restart 120
1 out of 1 Total Num of Neighbor Entries displayed.
OSPF Virtual Neighbor - GlobalRouter
NBRAREAID NBRROUTERID VIRTINTFID NBRIPV6ADDR STATE
0 out of 0 Total Num of Virtual Neighbor Entries displayed.
OSPF NBMA Neighbor - GlobalRouter
INTERFACE NBRROUTERID NBRIPADDR STATE
0 out of 0 Total Num of NBMA Neighbor Entries displayed.
Use the data in the following table to use the show ipv6 ospf lsdb commands.
Variable |
Value |
adv-rtr <A.B.C.D> |
Shows information for the specified advertising router. |
area <A.B.C.D> |
Shows information for the specified area. |
detail |
Shows information beyond the basic information. |
interface gigabitethernet {slot/port[/sub-port]} |
Identifies a single slot and port. If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
lsa-type <1-11> |
Shows information for the specified LSA type. |
lsid <0-4294967295> |
Shows information for the specified link-state ID. |
scope <1-3> |
Shows information for the specified scope:
tunnel <1-2000> |
Specifies the ID number of the tunnel. |
vrf WORD<1-16> |
Specifies the VRF name. |
vrfids WORD<0-512> |
Specifies VRF IDs. |
