This procedure only applies to VSP 8400 Series, VSP 4900 Series, and 5520 Series.
Use the following procedure to display information about all participants in an MKA session. You can also display MKA information for a specific port participating in an MKA session.
The following example displays information for all participants in an MKA session.
Switch:1(config)#show macsec mka participant
MACsec MKA Participants
Port CA MKA-Profile MKA Actor
Id Name Name Enable Priority
1/3 CA120022 extreme030519 Enabled A
1/4 CA121023 extreme031519 Enabled 14
2/2 CA122024 extreme032019 Enabled 1E
The following example displays information for a specific port participating in an MKA session.
Switch:1(config)#show macsec mka participant 1/3
The following table defines parameters for the show macsec mka participant command.
| Variable | Value |
| {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]} |
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
verbose |
Displays detailed information for a specific port participating in an MKA session. |
