A T5 controller uses the IPX operating system to manage its connected radio devices, as opposed to the WiNG operating used by RFS wireless controllers and NX service platforms. However, a T5 controller, once enabled as a supported external device, can provide data to WiNG to assist in a T5‘s management within a WiNG supported subnet populated by both types of devices. The Customer Premises Equipment (CPEs) are the T5 controller managed radio devices using the IPX operating system. These CPEs use a DSL as their high speed Internet access mechanism using the CPE‘s physical wallplate connection and phone jack.
To navigate to this instance, use the following commands:
<DEVICE>(config-profile-<PROFILE-NAME>)#? T5 Profile Mode commands: cpe T5 CPE configuration interface Select an interface to configure ip Internet Protocol (IP) no Negate a command or set its defaults ntp Configure NTP override-wlan Configure RF Domain level overrides for wlan t5 T5 configuration t5-logging Modify message logging facilities use Set setting to use clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal <DEVICE>(config-profile-<PROFILE-NAME>)#
The following table summarizes T5 profile configuration mode commands:
| Command | Description |
| cpe | Configures T5 CPE related settings (IP address range and VLAN) |
| interface | Configures the T5 controller‘s interfaces |
| ip | Configures the default gateway‘s IP address |
| no | Removes or reverts this T5 controller profile settings |
| ntp | Configures the NTP server associated with this T5 profile |
| override-wlan | Configures the RF Domain level overrides for applied on a WLAN on this T5 profile |
| t5 | Configures the logged T5 controller‘s country of operation |
| t5-logging | Configures a maximum of 5 (five) remote hosts capable of receiving syslog messages from this selected T5 controller |
| use | Defines this T5 profile‘s management settings |
Print
                        this page
Email this topic
Feedback
