fallback
Enables fallback to destination-based routing. This option is enabled by default. To disable fallback, use the no → fallback command.
The action taken for packets satisfying the match criteria is determined by the mark (action) clauses. If no action is defined, the default is to fallback to destination-based routing.
If no mark clause is configured and fallback to destination-based routing is disabled, then the packet is dropped.
  • Access Points — AP7502, AP7522, AP7532, AP7562, AP7602, AP7612, AP7622, AP7632, AP7662, AP8163, AP8432, AP8533
  • Wireless Controller — RFS4010
  • Service Platforms — NX5500, NX7500, NX9500, NX9600, VX9000
Syntax
fallback
Parameters
None
nx9500-6C8809(config-routing-policy-testpolicy-route-map-1)#fallback
Related Commands
no (route-map-config-mode-command) Disables fallback to destination-based routing if no next hop is configured or are unreachable
