ex3500-std-access-list
An EX3500 standard ACL is a policy-based ACL that contains a set of filter criteria and action that is applied to traffic originating from a specified source.
The following table summarizes IPv4 EX3500 standard ACL configuration commands:
EX3500-Standard-Access-List-Config Commands
Command Description
deny (ex3500-std acl) Creates a deny rule that rejects packets from a specified source or sources. The source can be a single device or a range of devices within a specified network. Use this command to also edit an existing deny rule.
permit (ex3500-std acl) Creates a permit rule that allows packets from a specified source or sources. The source can be a single device or a range of devices within a specified network. Use this command to also edit an existing permit rule.
no (ex3500-std acl) Removes a deny and/or a permit access rule from this IPv4 EX3500 extended ACL
To implement the EX3500 standard ACL, apply it directly to a EX35XX device, or to an EX35XX profile. For more information, see access-group.
