password-entry
Configures user-account lockout and unlock parameters. Use this option to configure the maximum number of consecutive, failed login attempts allowed before an account is locked out, and the duration of lockout.
  • Access Points — AP7502, AP7522, AP7532, AP7562, AP7602, AP7612, AP7622, AP7632, AP7662, AP8163, AP8432, AP8533
  • Wireless Controller — RFS4010
  • Service Platforms — NX5500, NX7500, NX9500, NX9600, VX9000
Syntax
passwd-entry role [device-provisioning-admin|helpdesk|monitor|network-admin|security-admin|
superuser|system-admin|vendor-admin|web-user-admin] max-fail <1-100> lockout-time <0-600>
Parameters
passwd-entry role [device-provisioning-admin|helpdesk| monitor| network-admin| security-admin| superuser|system-admin|vendor-admin| web-user-admin] max-fail <1-100> lockout-time <0-600> Configures user-role based account lockout criteria
  • role – Select the user-role. The options are:
    • device-provisioning-admin
    • helpdesk
    • monitor
    • network-admin
    • security-admin
    • system-admin
    • vendor-admin
    • web-user-admin
      • max-fail <1-100> – Specify the maximum number of consecutive, failed attempts allowed before an account is locked. Specify a value from 1 - 100.
        • lockout-time <<0-600> – Specify the maximum time, in minutes, for which an account remains locked. The value ‘0‘ indicates that the account is permanently locked. Specify a value from 0 - 600 minutes.
When configured, the lockout is individually applied to each account within the specified role/roles. For example, consider the ‘monitor‘ role having two users: ‘user1‘ and ‘user2‘. The max-fail and lockout-time is set at ‘5‘ attempts and ‘10‘ minutes respectively. In this scenario, user2 makes 5 consecutive, failed login attempts, and the user2 account is locked out for 10 minutes. However, during this lockout time the user1 account remains active.
Note: In the event-system-policy context, enable ‘login-lockout‘ and ‘login-unlocked‘ event notification to trigger e-mail or syslog notification to users on occurrence of the login-lockout and login-unlock events. For more information, see event.
rfs4000-6DB5D4(config-management-policy-default)#passwd-retry role monitor max-fail 5 lockout-time 10
rfs4000-6DB5D4(config-management-policy-default)#show con
management-policy default
no telnet
no http server
https server
ssh
user admin password 1 979cfb9288837ee26d74d07b5ea328fd0e9a2b55cf5104649c2b496cc94e7003 role superuser access all
passwd-retry role monitor max-fail 2 lockout-time 5
snmp-server community 0 private rw
snmp-server community 0 public ro
snmp-server user snmptrap v3 encrypted des auth md5 0 admin123
snmp-server user snmpmanager v3 encrypted des auth md5 0 admin123
Related Commands
no Removes the user-account lockout and unlock parameters configured here
