rest (ble-data-export-commands)
Configures the third-party, BLE-locationing server‘s URL. This is the external resource to which WiNG APs forward BLE data (UUID, RSSI, etc.) using the REST API. The data is forwarded in the JASON format.
  • Access Points — AP-7612, AP7632, AP7662, AP-8432, AP-8533
  • Wireless Controllers — RFS 4000
  • Service Platforms — NX 5500, NX 75XX, NX 95XX, NX 96XX, VX 9000
Syntax
rest <URL>
Parameters
rest <URL>
rest <URL>
Configures the third-party server's URL
  • <URL> – Enter the URL. This is the location of the resource to which WiNG APs send real-time RSSI feeds.
ap8432-070235(config-ble-data-export-policy-test)#rest https://test.com/12/
ap8432-070235(config-ble-data-export-policy-test)#show context
ble-data-export-policy test
The following example shows the configurations will have to configure the following parameters to enable BLE data forwarding:
  1. On the WiNG AP‘s profile/device context, configure the following Bluetooth parameters:
    ap8432-070235(config-profile-test-if-bluetooth1)#mode le-sensor
    ap8432-070235(config-profile-test-if-bluetooth1)#no shutdown
    ap8432-070235(config-profile-test-if-bluetooth1)#show context
     interface bluetooth1
      no shutdown
      mode le-sensor
    This enables the AP as a BLE sensor.
  2. On the APs‘ controller,
    1. Configure a BLE data export policy, pointing to the external, third-party, REST end-point.
      NOC-NX9500(config-ble-data-export-policy-test)#rest https://test.com/12/
    2. Configure a sensor policy.
      NOC-NX9500((config-sensor-policy-test)#rssi-interval-duration 30
    3. Navigate to the BLE-enabled, WiNG AP‘s RF Domain context and:
      • Use the BLE data export policy, configured in step 2a.
        NOC-NX9500(config-rf-domain-ble)#use ble-data-export-policy test
        This enables BLE data forwarding to the external, third-party server specified in the policy.
      • Use the sensor policy, configured in step 2b.
        NOC-NX9500(config-rf-domain-ble)#use sensor-policy test
        When applied, BLE data is forwarded at the interval specified in the sensor policy.
Related Commands
no (ble-data-export-commands)
Removes the REST endpoint URL configuration
interface-config-bluetooth-instance
Documents AP profile/device Bluetooth interface configuration commands
sensor-policy
Documents the Sensor policy configuration commands
use (rf-domain-config-mode)
Applies the ‘BLE data export policy‘ and ‘Sensor policy‘ on the RF Domain
