IP flow data is exported using templates that contain supporting data record fields.
To enable IP flow data collection and export within your WiNG 7.3.0 managed network, create a NetFlow policy and apply locally on the AP or in the AP's profile context. The NetFlow policy identifies the NetFlow Collector host and specifies the interval at which templates are exported to the specified NetFlow Collector.
NetFlow is only supported on the following 802.11ax APs: AP410i/e, AP460i/e, AP505i, AP510i/e, AP560i/hTo define a NetFlow Policy:
| Name | Lists the 32 character maximum name assigned to each listed Netflow Policy. |
| Collector Address | Lists the NetFlow Collector host's IPv4 address. |
| Collector Port | Lists the port at which the NetFlow Collector can be reached. |
| Protocol | Lists the protocol used to communicate with the Netflow
                                        Collector. Note: The current implementation only supports
                                            UDP protocol.  |
| Template Interval | Lists the interval, in seconds, at which the AP (Exporter) exports NetFlow templates to the specified NetFlow Collector host. |
| Collector Address | Specify the NetFlow Collector host's IPv4 address or hostname |
| Collector Port | Specify the port on which the NetFlow Collector host is
                                        reachable. Set a value from 1 - 65,535. Note: The
                                            default port value is 2095. |
| Protocol | Specify the protocol type used to communicate with the
                                        NetFlow Collector host. The options are TCP and UDP. Note: The
                                            current implementation only supports UDP protocol. The
                                            default value is UDP. |
| Interval Template | Specify the interval, in seconds, at which the AP
                                        NetFlow Collector host. Set a value from 300 - 3600 seconds. Note: The default value is 300 seconds. |
