SES-imagotag‘s ESL (Electronic Shelf Label) tags are small, battery-powered devices used by retail businesses to display information, such as product code, pricing, etc. These tags are activated, configured, and managed through an SES-Imagotag provided server. The tags and server communicate through an ESL communicator (a USB dongle), connected to the USB port on the WiNG AP. This communication is over the 2.4 GHz band using a proprietary RF protocol. The ESL communicator acts as a bridge between the tags and the server, using WiNG AP as an infrastructure device.
Use this option to enable support for SES-imagotag‘s ESL tags on WiNG APs with USB interfaces. In case of standalone AP's, apply the policy to the AP‘s self. In case of adopted APs, the policy is pushed to the AP through the adopting controller. In the latter case, apply the policy on the AP‘s profile.
Starting with WiNG 7.4.0, Imagotag support is available on AP360i/e, AP310i/e, AP410i/e, AP460i/e, AP505i, AP510i/e, AP560i, AP560h, in addition to AP-8432.
Important
This feature is supported only on AP's with USB ports. Ensure the AP is using PoE+ (802.3at) power for the USB port to be enabled.
Your AP will not communicate with the ESL server with any exisiting or older versions of Imagotag configuration.In WiNG 7.4.0, the Imagotag ESL solution is upgraded with secure connectivity between AP and ESL server on-prem or on-cloud. Any unencrypted mode of communication between AP and ESL server is not supported in WiNG 7.4.0 release.
For configuration information, refer to the Extreme Wireless Controller, Service Platform and Access Point CLI Reference Guide.
To navigate to the Imagotag Policy screen:
| Imagotag Name | Displays the Imagotag policy name. |
| Enable | Displays the status of the policy: Enabled/Disabled. A green check mark indicates that the policy is enabled. A red cross mark indicates that the policy is disabled. |
| Channel | Displays the channel assigned for ESL communicator to tag communication in the 2.4 GHz band. |
| Window Size | Displays the transmission window size for messages exchanged between ESL communicator and tags. |
| Payload Size | Displays the maximum payload size in packets exchanged between ESL communicator and tags. |
| Output Power | Displays the maximum output power set for the ESL communicator. |
| SSL | Displays if Secure Socket Layer (SSL) encryption mode of communication is enabled or not. A green check mark indicates that this option is enabled. A red cross mark indicates that this option is disabled. |
| FCC-Mode | Displays if the FCC compatibility mode is enabled or not on the ESL communicator. A green check mark indicates that this option is enabled. A red cross mark indicates that this option is disabled. |
