This section describes the antenna-id configuration for the AP510e and AP560h model access points.
The ExtremeMobility AP510e access point is a dual-radio access point, with eight, external Wi-Fi antennas grouped into: group-1 (antenna ports 1 to 4) and group-2 (antenna ports 5 to 8). To enable the AP510e radio, it is mandatory to configure the antenna-id. The antenna-id parameter specifies the antenna type used in the group-1 and/or group-2 antenna ports.
| Antenna Ports | ||
| Software Mode | 2.4/5G Antennas: 1, 2, 3, 4 | 5G Antennas: 5, 6, 7, 8 |
Mode 1
 Note: This mode requires only FOUR, dual-band antennas connected to ANT sockets 1
                                            to 4.
                                    Dual-band 2.4 GHz/5 GHz | None |
Mode 2
 Note: This mode requires FOUR, dual-band antennas connected to ANT sockets 1
                                            to 4, and FOUR, 5G-band antennas connected to ANT sockets 5 to
                                            8.
Mode 3
 Note: Requires FOUR, 5G-band antennas connected to ANT sockets 1 to
                                            8.
                                    5 GHz | 5 GHz |
The ExtremeMobility AP560h access point is a dual-radio access point, with eight, internal Wi-Fi antennas, supporting two internal antenna modes: 30 degree and 70 degree.
To enable the AP560h radio, it is mandatory to configure the internal antenna mode as '30 degree' or '70 degree'.
To override the AP510e/ap560h access point profile's antenna-id configuration at the device level:
The selected device's configuration menu is displayed.
AP510e antenna-id configuration
This configuration is needed only if the target device-type is AP510e.| Antenna ID Group 1 Option | Use this drop-down menu to configure the antenna type
                                        used in the antenna ports 1 to 4 (group-1 antennas).  The antenna types supported for 'group-1' and 'group-2' antenna ports are: ai-dq04360s, ml-2452-apa2-01, ml-2452-apa2-02, ml-2452-hpa5-036, ml-2452-hpag4a6-01, ml-2452-hpag5a8-01, ml-2452-pna5-01r, ml-2452-pna7-01r, ml-2452-pta4m4-036, ml-2452-sec6m4-036, ws-ai-dq05120. The default setting is 'Default', that is no antenna-type associated with the group-1 antenna ports and the radio is disabled. Note: Group-1
                                            antenna configuration is required for all three software
                                            modes.
Note: Refer to
                                            the table above for the supported software modes
                                            and the corresponding antenna configurations
                                            required.
| Antenna ID Group 2 Option | Use this drop-down menu to configure the antenna type
                                        used in the antenna ports 5 to 8 (group-2 antennas).  The antenna types supported for 'group-1' and 'group-2' antenna ports are: ai-dq04360s, ml-2452-apa2-01, ml-2452-apa2-02, ml-2452-hpa5-036, ml-2452-hpag4a6-01, ml-2452-hpag5a8-01, ml-2452-pna5-01r, ml-2452-pna7-01r, ml-2452-pta4m4-036, ml-2452-sec6m4-036, ws-ai-dq05120. The default setting is 'Default', that is no antenna-type associated with the group-2 antenna ports and the radio is disabled. Note: Group-2
                                            antenna configuration is ONLY required for software mode
                                            3.
Note: Refer to
                                            required.
AP560h antenna-id configuration
This option is visible only if the device-type selected is AP560. This configuration is needed only if the target device-type is AP560h| Antenna ID Internal Option | Use this drop-down menu to configure the internal antenna
                                        mode. The options are:
