Smart RF Configuration and Deployment Considerations
         Before defining a Smart RF policy, refer to the following deployment guidelines to ensure the configuration is optimally effective:
            - Smart RF cannot detect a voice call in progress, and will switch to a different
               channel resulting in voice call reconnection.
- The Smart RF calibration process impacts associated users and
               should not be run during business or production hours. The calibration process should
               be performed during scheduled maintenance intervals or non-business hours.
- For Smart RF to provide effective recovery, RF planning must be
               performed to ensure overlapping coverage exists at the deployment site. Smart RF can
               only provide recovery when access points are deployed appropriately. Smart RF is not
               a solution, it's a temporary measure. Administrators need to determine the root cause
               of RF deterioration and fix it. Smart RF history/events can assist.
Keep in mind, if a Smart RF managed radio is operating in WLAN mode on a channel requiring DFS, it will switch channels if radar is detected.
            - If Smart RF is enabled, the radio picks a channel defined in the
               Smart RF policy.
- If Smart RF is disabled, but a Smart RF policy is mapped, the
               radio picks a channel specified in the Smart RF policy.
- If no Smart RF policy is mapped, the radio selects a random
               channel.
If the radio is a dedicated sensor, it stops termination on that channel if a neighboring access points detects radar. The access point attempts to come back to its original channel (statically configured or selected by Smart RF) after the channel evacuation period has expired.
         Change this behavior using a no dfs-rehome command
            from the controller or service platform CLI. This keeps the radio on the newly selected
            channel and prevents the radio from coming back to the original channel, even after the
            channel evacuation period.
