| Traffic Type | Use the drop-down menu to define
										the traffic type for which the Storm Control configuration
										applies. Options include ARP, Broadcast, Multicast and
										Unicast. |
									| Interface Type | Use the drop-down menu to define
										the interface for which the Storm Control configuration is
										applied. Only the specified interface uses the defined
										filtering criteria. Options include Ethernet, WLAN and Port
										Channel. |
									| Interface Name | Use the drop-down menu to refine
										the interface selection to a specific WLAN or physical port.
										This helps with threshold configuration for potentially
										impacted interfaces. |
									| Packets per Second | Select the check box to activate
										the spinner control used for specifying the packets per
										second threshold for activating the Storm Control
										mechanism. |
