You can add a location policy or manage existing policies to match your requirements.
To edit, copy, rename, or replace an existing policy, select the policy and click Edit, Copy, Rename or Replace respectively.
| Enable | By default the policy is enabled and the value displays as true. |
| Location Key | Enter your 64-bit ExtremeLocation tenant API key. This is
                                        the key the controller/virtual controller uses to
                                        authenticate with the ExtremeLocation server. Note: You can
                                            generate the API-Key from the ExtremeLocation UI. For
                                            more information, refer to the ExtremeLocation user
                                            guide, available at https://extremenetworks.com/documentation. |
Specify the server hostname and not the IP address, as the IP address is likely to change periodically in order to balance load across multiple location server instances.
By default the ExtremeLocation server is reachable on port 443.
